Old 07-08-2005, 11:35 AM
john78ta john78ta is offline
Default Coil Over Shocks
I am using a Wayne Due Front and Rear Suspension, what coilover shocks do you all use, and which work the best for the price.
John
1978 Pontiac Trans AM
LS1/T56
2002 Trans am Interior
Wayne Due Front Clip
Wayne Due IRS
Old 07-10-2005, 06:11 AM
XcYZ's Avatar
XcYZ XcYZ is offline
John, which Wayne Due front subframe are you using - C4, C5, or the AME style?
My LS7 69 Camaro
Old 07-10-2005, 09:50 AM
jonny51 jonny51 is offline
When I got my WD sub he recommended(and sells for that matter lol)QA1s.
Old 07-10-2005, 08:40 PM
GO67SS GO67SS is offline
Default Shock
I am using QA1's 12 pt adjustables on my stock modified frame (Fatman upper and lowers, 2in drop spindels, Baer brakes,) I love the way they ride
http://www.cardomain.com/ride/662136
Drive it like you stole it!
Old 07-31-2005, 05:11 AM
Majik16106 Majik16106 is offline
qa1 all the way, or go all out and get some penske's or afco set up. qa1 makes good stuff, good price..
Old 07-31-2005, 11:31 AM
Mean 69 Mean 69 is offline
Though expensive, I can't say enough about the Penske's on my car. There really is a difference when you make an adjustment, though I have not had direct experience with some of the lower end adjustable shocks, many people that I have talked to say that adjustments sometimes can't even be felt in the car. The Penske's are standard fare in most auto racing, so there a bunch of folks out there who can revalve and service them. The guys at Hoerr racing are excellent to work with if you are in the market for these.
Other high end adjustable shocks are Ohlin, Moton, both seem to be around the same price as the Penske's (about $700 per corner for double adjustable, $1100 per corner for triple adjustables).
Keep in mind, this is an instance where you really do get what you pay for.
Mark
