Old 12-10-2004, 01:11 PM
Gmac454's Avatar
Gmac454 Gmac454 is offline
Default 68 coupe and convert suspension
i am looking to go 17 or 18 inch wheels on my 68 coupe and my convert. they are stock small block cars, with the exception of disc brakes on the front and multi-leaf rear's. what is the best way to find out what tires and rims will clear the fenders and frame with out buying up front and then finding that you are hosed. I am planning on re-doing the suspension like jer67convert but the thought of spending a ton of dough to find out i dropped the front end too much for the rims to fit isn't a happy thought.
thanks
Old 12-10-2004, 03:50 PM
XcYZ's Avatar
XcYZ XcYZ is offline
17 or 18x8 with 4.75" of BS and a 245/40 in the front and a 17 or 18x9.5 with 5.5" of BS and a 275/40 in the rear will work great.
My LS7 69 Camaro
Old 12-10-2004, 04:01 PM
BC69's Avatar
BC69 BC69 is offline
Just to add to what Scott said, the backspacing is key. With the stock car, I think 8" is the biggest you can fit in the front, but need at least 4.5" backspacing. The back can take a 9.5 at max and still clear the fender well if it has 5.5" backspacing. The tire size will affect if it rubs too, so be moderate about how big a tire you use, but 240 and 275 will be a nice fit without pushing the limits.
Good Luck
Tim
In memory of those gone before us
In gratitude for those who care.
