Old 02-21-2008, 04:41 AM
Default Fuel line facts for LS7
Hello ,
What is the needed fuel line size for LS7 . Is 10mm - 3/8" inside diameter of the pipe enough ??
63 Z06
Old 02-21-2008, 05:28 AM
Payton King's Avatar
Default I do not have an LS7
But I find most people, myself included, are running a AN -8 from the tank to the fuel rail on LS motors.
If you are running a return system at the fuel rail back to the tank...AN -6.
I have mine dead headed at the fuel rails, so I have -8 to the rail. The regulator is next to the tank and I am running a -6 back into the tank.
Here is a shot...although I have since changed all lines to the high dollar stuff to eliminate the gas smell
Old 02-21-2008, 05:49 AM
Thank you Payton,
I think AN 8 is close to 3/8" - 10 mm at ID. Thanks!!!!
Ps looks really nice underneath
63 Z06
Old 02-21-2008, 06:19 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Originally Posted by Bowtieracing
Thank you Payton,
-8 AN means 8/16"..... 1/2" inch ID.
My LS7 69 Camaro
Old 02-21-2008, 06:37 AM
Steve1968LS2's Avatar
Yea, I'm running 8AN to the fuel rail with my regulator back by the tank. I return to the tank with a 6AN.
No issues at all.
Old 02-21-2008, 09:42 AM
Efi69Cam Efi69Cam is offline
In the AN spec, the - number indicates the number of 16ths of an inch the ID of the hose is. so a -6 is 6/16" or 3/8" and the -8 is 8/16" or 1/2"
Old 02-21-2008, 10:46 AM
Thanks guys !! This was good info. How wrong i have been long time.
One more question, can i just use the stock vette regulator and filter and run just one line to the stock fuel rail ?
63 Z06
