Old 02-21-2008, 06:43 PM
unwrittenlaw191 unwrittenlaw191 is offline
Default 1969 Camaro rearend width?
What is the stock width on 69 camaro? Also with running a DSE mini-tub how much narrower can you go and still get an avalible backspacing?
Dustin
Old 02-21-2008, 06:58 PM
68protouring454's Avatar
60 inch is stock width.
55 to 55.5 or so is the common width for use with a 12 inch wheel and 6 inch backspacing.
Jake's Rod Shop
Old 02-21-2008, 07:17 PM
I am sorry is this backing plate to plate or axle to axle or....?
Old 02-21-2008, 07:36 PM
this is axle flange to axle flange
Jake's Rod Shop
Old 02-21-2008, 07:44 PM
ItDoRun's Avatar
ItDoRun ItDoRun is offline
Call DSE. They were very helpful.
Chris
Old 02-21-2008, 08:21 PM
Yup, Jake is correct. We sell and install lots of Mosers for mini tub, 55" flange to flange (including rotors / drums) and 6.2" backspace and you have a tick of wiggle room to shim if you need to.
Frank Serafine
Old 02-23-2008, 10:14 AM
67rstbkt 67rstbkt is offline
Would these same dimensions apply to a 1967? I'm planning on DSE minitubs but with a 17x11 rear width.
Old 02-23-2008, 11:55 AM
With a 11" wheel I would do a 5 3/4" Backspace with a 55" rear.
Frank Serafine
Old 02-23-2008, 06:26 PM
