Old 02-24-2008, 07:10 PM
projects projects is offline
Default Correct way to cut a coil spring?
What and where is the best way to cut the rear coils for 2-2.5" of drop from a 1" drop spring?
Im going to run a Eibach pro kit on a 66 chevelle, this has a 1" drop in the back from the start.
THANK YOU
JOHN R
04 3/4 ton chevy 5spd 6.0
White 66 chevelle malibu - just starting the project
ls 6.0, 6spd, and who knows
http://i17.photobucket.com/albums/b5...CTS/Front2.jpg
Orange 71 Camaro wild 396 BB gone :-( http://www.cardomain.com/ride/503317
68 SS Camaro yellow mild 350/400 sold
63 SS Impala 4spd white wild 400 sold
69 GT Torino red auto 351 sold
66 Malibu Chevelle brown 4spd 283 sold
Old 02-24-2008, 07:34 PM
chicane's Avatar
chicane chicane is offline
Well... first of all, that peticular spring is a progressive rate design. If you cut it... you will ruin the spring. Its not like cutting a linear spring, as you can do that successfully without issue... but not with a progressive rate design. Not to mention that its not a linear drop when you cut linear amounts to begin with, linear rate or not. One quarter cut could yield 1/4" drop. The next quarter coil could drop an inch and a half. So if you do this... just remember one thing: Cut the least amount possible to get the ride height you want... as you can always cut more... but you can never add it back.
Anyway. I learned from one of the cats that started doing this kinda thing some 56 plus years ago. What I have learned in cutting springs is that its all about transfering as little heat to the spring material itself as not to change more of the spring properties than necessary. Thus far, I have only found two ways to do this...
1. Ox/acetylene. Put the spring in a bucket, fill that bucket with sand and cut the spring hot and fast... allowing it to air cool. Next, grind the cut end to clean it up.
2. Cold saw. Liquid bath, slow speed, air cool. This normally has a much nicer end cut finish but it is much harder to fit a spring into a cold saw.
Also not to forget... when you change the height of the spring your greatly change the damper valving requirements. So some adjustable shocks will help.
Old 02-24-2008, 08:49 PM
zbugger's Avatar
zbugger zbugger is offline
'66 Chevelle? I could be wrong, but the rear coils on that car are pig tailed on both ends. You can't cut those springs to get a greater drop. You'll just have to use different springs to achieve what you want.
Lost in a hopeless world on a path that wanders aimlessly and endlessly... As if it really even mattered.
Old 02-24-2008, 09:04 PM
chicane's Avatar
Yeah they are both pig tailed... one end more than the other. But, you can flat perch the upper pocket (or use a jack screw perch) and use a cut spring.
Old 02-24-2008, 09:12 PM
zbugger's Avatar
Yeah, but you gotta remember that like most others, I'm lazy. That would be too much work for me.
Old 02-24-2008, 10:11 PM
surreyboy
Guest
Posts: n/a
you can heat them and make em sag, but thats worse then cutting them, coil overs?
Old 02-28-2008, 05:04 PM
MarkM66's Avatar
MarkM66 MarkM66 is offline
My all original '66 rear springs were pigtail on one end only.
Cut off wheel works fine for cutting coils too.
