Old 03-05-2008, 02:08 PM
Steve1968LS2's Avatar
Default New '67 & '68 gauge cluster.. pretty cool.
Got a press release on this and thought it was pretty cool. Surprised it took someone this long to offer one. I think it's around $1000, so it's not cheap.. but it's pretty damn cool.
1967-68 Camaro Gauge Cluster
Features:
Complete gauge assemble: New Instrument Housing OEM aftermarket
5” Combination 140 MPH/ 8K Speedo / Tach
5” Combination Quad gauge, Temp, Volt, Oil, Fuel
All gauges are electronic 12 volt
Black Aluminum Bezels
Real Curved Glass
Wiring Harness with GXL18 color coded wires and connecter
All gauges mounted into housing for easy installation.
Sending units for Speedo, Temp, Oil, & Fuel to work
with stock fuel 0-90 ohm sender.
Three Series Chooses: Standard
“Hot Rod Series” -----Black dials with white font and pointers
“White Hot Series”---White dials with black font and pointers
“G Stock Series”------ Black dials with mint green font and fluoscent orange pointers
Support:
All Classic Instruments gauges are backed with a 5 year warranty.
Pros:
Complete gauge cluster, all senders, mounting housing, bracket and wiring harness are included.
Competitively priced
Built in the USA
Bolts right back into stock dash with no alterations (wiring changes are needed as are gauges are all electric).
Custom colors and styles can be built (extra charge and time needed)
Have senders for all makes and model of any engine / trans combination customer may use.
Turn Signal indicators incorporated into the cluster
Old 03-05-2008, 02:33 PM
wiedemab's Avatar
wiedemab wiedemab is offline
I could have sworn that I saw these at one of their displays last year - maybe it was just the gauges that look similar. There stuff looks really nice!
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 03-05-2008, 03:40 PM
Musclerodz's Avatar
Those have been on their website for awhile now. Probably trying to get them to start selling. However that price is hard to swallow.
Mike
Mike Redpath
Musclerodz & Customz
facebook page
Old 03-05-2008, 04:46 PM
cetchup's Avatar
cetchup cetchup is offline
I did this 2 years ago. The gauges were intended for a 48 Chevy Pass. I told them then I was putting them in a 68 Camaro.
Name:  Picture 404 (Large).jpg
"Later" J.J.
Old 03-05-2008, 06:22 PM
7TSS's Avatar
7TSS 7TSS is offline
Attachment 11060
So what did just the gauges cost. How hard was it to fit in the Camaro cluster.
Old 03-05-2008, 06:39 PM
cetchup's Avatar
I don't remember the exact cost, Less than $1000. Be sure and specify
correct ohms resistance for Camaro tank sending unit if you order gauges
only. Simple install, I cut the orig. retainer to fit new gauges. Hi-beam
and turn indicaters took longer than gauge install.
"Later" J.J.
