Old 03-11-2008, 11:03 AM
Jimmy Sean's Avatar
Jimmy Sean Jimmy Sean is offline
Talking My Firebird build
First off my name is Sean James and I’m introducing my project and starting a build thread. I bought my 1969 Firebird on October 1st, 2000.
It started off to be just a driver, get it running and drive until I get my Camaro done. I had it running in two days and then I started cleaning the engine and engine compartment. I thought I might as well blow the heads off and re-gasket the engine plus it makes it easier to clean. Well there were holes in two pistons, so I went out and bought a remanufactured Pontiac 350 short block, had the heads rebuilt and bought an Edelbrock intake. For the money I spent on it I should have bought a LS1. Oh well. Skip to today, second house and two more kids.
I have acquired many parts and I’m ready to just get it drivable. So my theme for this is JUST GET THE DANG THING RUNNING AND DRIVE IT! Also the budget is small (by small I mean try not to spend money frivolously and only on things that are necessary) considering I have four kids, house, wife and one income.
Here is the basic plan. Power will be from the Pontiac 350, 290-340 horsepower with 400 lb-ft of torque backed by a T-56. Later I will swap it out for a 5.3L LS out of a truck and add the turbos I already have.
Front suspension has the Guldstrand mod with hybrid 13” c4/c5 brakes and Z06 red calipers and hydroboost brake assist from Hydrotech. It also has hidden spring adjusters installed and poly urethane bushings that will be swapped for Delrin or equal after I start driving it. Steering box will be upgraded but I haven’t decided on what box to go with. Eventually I want to get the adjustable a-arms from SC&C.
For the rear it has 3” drop leaf springs and offset shackles from SpeedTech. 12 bolt out of a Chevelle with 4:10 gears and a posi. Later it will be converted to a coilovers and a torque arm setup. I need the back seat for the kids so that leaves out any 3-link. Brakes are from a LS1 Camaro with Z06 calipers.
Wheel and tires, Front 17x9.5 with 275/30-18 and the rears are 17x12 with 335/35-18. Front tires and wheels will be delivered today. I will hopefully post up some pictures tonight. They were cheap one piece wheels and I’m having the rears widened but they look a lot like the HRE 547.
Here are the wheels I bought.
Body and paint will be minimal for now but the plan is to shoot it in a flat or semi gloss dark green primer/sealer, nearly black with a lime green stripe.
My goal is to have it drivable in May for my birthday.
Old 03-11-2008, 12:50 PM
Tom.A's Avatar
Tom.A Tom.A is offline
That's alot of rubber. I agree with just get the thing going. It is real easy to get side tracked for years without a running car. I plan to stop changing my mind soon and make progress. Post up those pics when you have them.
Tom
Old 04-14-2008, 07:30 AM
Jimmy Sean's Avatar
Well I bought a camera over the weekend, a Canon PowerShot A720 IS. Some pictures will be posted tonight for your viewing pleasure .
1969 Firebird, L-76 LS2, T56, Speed Tech Torque Arm, Build Thread
Instagram @jimmysean69
Old 04-14-2008, 07:36 AM
XcYZ's Avatar
XcYZ XcYZ is offline
You know how we love pics.
My LS7 69 Camaro
Old 04-14-2008, 07:40 PM
Jimmy Sean's Avatar
Here are some pictures. First here are some hubs that I have. The left one is a two piece disk brake hub and the one on the right is a drum hub.
This is the bracket I made for the disk brake conversion. you can also see the s10 bump stop.
C4 13" rotor and C5 caliper.
With wheel and tire.
Old 04-14-2008, 07:48 PM
Jimmy Sean's Avatar
Here is the money shot.
Front tire.
Here is a rear wheel that I had widened from 9.5" to 12" by WeldCraft Wheels, cost was $225 each wheel.
For fun, three of my kids. Titus, Destiny and Haley.
Old 04-14-2008, 08:17 PM
XcYZ's Avatar
That's the money shot.
My LS7 69 Camaro
Old 04-14-2008, 08:41 PM
awr68's Avatar
awr68 awr68 is offline
That's great!!
Tony
'68 Camaro
Old 04-14-2008, 09:41 PM
Wow I really like those wheels. I looked them up and found them to be the MB "Essen" wheel. Do they come in a variety of offsets or did they just happen to fit on the first gen? I might consider a set of these myself as the price is very nice.
Thanks,
William
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
Old 04-15-2008, 02:44 AM
Speedster's Avatar
Speedster Speedster is offline
I agree with Scott. The kids in the wheel is the money shot. Keep the pics coming. Go Firebird...
-Bruce
Project "Freebird"
Dyno Video
http://www.nelsonracingengines.com/...lownbbchigh.wmv
Project Rides:
1968 Firebird - Blown 540
1987 Blazer 4x4 - Blown 355
2007 Magnum
2010 Camaro SS - LSX Twin Turbo
