Old 03-11-2008, 09:25 PM
RBR's Avatar
RBR RBR is offline
Default Sub frame connector install?
I was attempting to install my subframe connectors the bolt in type, and I found that it is hitting in couple spots on the floor pan. My first thought was to get a rubber mallet and give it a couple wack's. Is there a better way to make a couple indentions. It's for my 69 bird. Thanks in advance.
Old 03-11-2008, 10:24 PM
awr68's Avatar
awr68 awr68 is offline
If you want to control it a little better than just hammering the floor, lay a piece of pipe or wood against the floor and hit that. This will make for a nicer indention and be a little easier on the floor.
Tony
'68 Camaro
Old 03-12-2008, 06:46 AM
Silver69Camaro Silver69Camaro is offline
Or use a floor jack and press it up into place, if possible. That way you don't leave hammer marks.
Matt Jones
Mechanical Engineer
Art Morrison Enterprises
Old 03-12-2008, 09:47 AM
RBR's Avatar
RBR RBR is offline
Thank's I was looking for something better then the ol hammer. I thought about the floor jack, but thought maybe it would push up and make a very large dent. I'll go back rethink things. I already painted my bottom so I'm trying to minimize the paint damage also. Thanks for the replies.
Old 03-12-2008, 10:50 AM
awr68's Avatar
That's a great idea Matt! I'm sure it doesn't need much...otherwise I would call that a problem with the product!
Tony
'68 Camaro
Old 03-12-2008, 12:58 PM
Hope you didn't use POR15. Got that stuff on my fingers one time and took weeks to get it off! Hate to have it on my butt!!
Sorry, I couldn't resist.
Matt Jones
Mechanical Engineer
Old 03-13-2008, 12:51 PM
RBR's Avatar
RBR RBR is offline
LOL, well I did use por 15 and I had it every place except for my butt. It's been about a 1 1/2 yrs now and I think it's finally off me by now
Old 03-13-2008, 07:18 PM
another69 another69 is offline
Whose bolt in connectors are you using?
Old 03-14-2008, 09:57 AM
RBR's Avatar
RBR RBR is offline
I went with Competition Engineering, only because I have an aftermarket subframe and they would fit w/o any fab work.
Old 03-17-2008, 12:41 PM
RBR's Avatar
RBR RBR is offline
Default It's Done!
Well, I finally got the subframe connectors bolted up. Not direct bolt in, had to oblong some holes and also shim the connectors where they connect to the leaf spring cup/perch (not sure what its called). The directions want you to sandwich the connectors under the cup/perch but for some reason I had a 1/4 inch gap on one of the mating surfaces. I had to add a couple washers to make up the gap. I'll try and take some pic's.
I'm still icing the lump on my forehead from dropping a part on my head and also working out the kinks in my neck from being layed out on my back for so long.LOL
