Old 03-17-2008, 08:36 PM
XcYZ's Avatar
XcYZ XcYZ is offline
Default ATS splined sway bar installed
This isn't a huge update by any means, but thought I'd share some pics of the ATS splined sway bar because it's such a nice setup. I drilled multiple holes in the arms for some adjustability and made a pair of small brackets that attach the end links to the body. The bottom side of my frame rails are are solid steel that's about .250" thick, so I drilled and tapped 2 holes at 1/2-13 and used allen head bolts to mount them. They feel extremely solid and I have to believe the splines on the aluminum arms would fail before the threads would.
My LS7 69 Camaro
Old 03-17-2008, 08:54 PM
awr68's Avatar
awr68 awr68 is offline
Looks very nice Scott!
Tony
'68 Camaro
Old 03-17-2008, 08:59 PM
XcYZ's Avatar
Thanks, Tony. I just like taking pics.
My LS7 69 Camaro
Old 03-17-2008, 09:05 PM
awr68's Avatar
Do you know if they are ready to ship yet? Not sure I need one and it probably would be a lot trickier to install on my car...but I'm always looking into all the new products!
Tony
'68 Camaro
Old 03-17-2008, 09:12 PM
XcYZ's Avatar
Yep, I believe so.
I'm not sure how much rear bar my car will need, but I figured now was the time to do it.
My LS7 69 Camaro
Old 03-18-2008, 03:43 AM
Sales@Dutchboys's Avatar
SWEEEETT!!!!
Paul
dutchboyshotrods.com
269-823-2967
Old 03-18-2008, 05:50 AM
James OLC's Avatar
A very nice piece and as always well engineered. It should be a great tuning aid.
James
1967 Camaro RS - The OLC
1967 Camaro RS - Recycler
1969 Camaro - Dusty
Old 03-18-2008, 10:35 AM
dave96dcm dave96dcm is offline
That loks real good, the only think that I can think of is it might be a better idea to use double shear endlinks, that way it won't fatige the aluminum as much.
Old 04-10-2008, 06:06 PM
68turboSS 68turboSS is offline
that is a clean setup.....very nice piece.
