Old 03-26-2008, 08:36 AM
1 Dwn Cam's Avatar
1 Dwn Cam 1 Dwn Cam is offline
Default Header Gaskets. Fel-Pro or Silicone?
I am about to install my headers. AFR heads calls for a 1405 Fel-Pro and to torque my ARP bolts to 20 lbs with anti seize. ARP calls for 36 lbs on their bolts and says that a bead of clear silicone on the flange of the header works better than a gasket. I would like to know which of the two would be the better way to go, so that the bolts don't back out and cause a exhaust leak. I want to do this one time and one time only.
This will give you an Idea.
http://www.cardomain.com/ride/2368130/1
Vrbancic Brothers Procharged 406
781.5 HP @ 6500
701 @ 5500
14 psi.
Old 03-26-2008, 09:55 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
The gasket isn't responsible for you bolts not backing out.
They need to be re-torqued after a few heat cycles.
I like Percy's soft aluminum gaskets. But I'm sure otheres work fine too.
Some headers (cheap) are harder to seal then others.
