Old 03-26-2008, 10:25 AM
DRJDVM's '69's Avatar
Default Recommended fuel pressure?
I'm running an Aeromotive a1000 pump and the corresponding regulator for a carb application... 434 small block with a 950 carb, around 600 HP
Is there a recommended fuel pressure I should shoot for???
I'm planning on doing a dyno tune once the motor is broken in and all the "glitches" are worked out, but I was hoping to at least get a good starting point.
I have it set at about 7 psi now....
Old 03-26-2008, 11:52 AM
Blown353 Blown353 is offline
6-7 psi is fine.
An A1000 will be circulating a LOT of fuel at that low of a pressure... keep an eye on the filter closely for a while as moving that much fuel will get your tank spotlessly clean in no time and move all the debris to the filter.
1969 Chevelle
Old 03-26-2008, 11:53 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Ned, that's pretty much the same setup I had, and I also ran 7psi and had no problems. I had an electric fuel pressure gauge in the dash and it never moved.
My LS7 69 Camaro
