Old 04-07-2008, 09:30 AM
sacarguy sacarguy is offline
Default Weld billet 18x10 wheels early camaro nova chevelle. ADDED PICS OF WHEELS ON 69 CAM
18x10 inch billet weld wheels
18x10 inches wide with 245 40 18 wheels all the way around 5 on 4.75 patern with 4.5 back space.
were machined to clear big brakes by weld when made I know for a fact they clear the 13 inch brembo setup as that was on the vehicle these came off.
not cheap to get these in this ofset and size as weld doesn't offer it its a special order deal not a off the shelf set.
also have the correct extra tall lug nuts for these that allow you to use extended studs without the studd sticking out of the lug nut.
These wheels were originaly on the unique performance HHR and have maybee 2-300 miles of use the car was never driven only loaded and unloaded from a trailer
wheels and tires cost just over 3k new.
asking best offer over 1800.00
Old 04-07-2008, 02:41 PM
38chevy 38chevy is offline
What city/state are the wheels and tires located ?
Why selling?
Ron
Old 04-07-2008, 03:09 PM
Default k
I know they fit a 69 camaro because my budy bolted them up to his .. and they looked sick.
and we remeasured them
they are 9.5 inches inside of lip to inside of lip 10 inches out side to outside of tire mounting lip
so they could be considered 10 or 9.5 inches wide.
here are some pics added for you to see how they fit on a 69 ..
Old 04-11-2008, 09:31 AM
Default k
added pics of wheels mounted
Old 04-12-2008, 10:43 AM
GinoRin GinoRin is offline
Where are you located? Think they will clear 14" rotor and 6 piston caliper?
Gino T. Rinaldi
[email protected]
87 Buick GN 52k miles, 11.40@121 (HRE 545s and C6 Z06 brakes are on!)
2005 Pontiac GTO Cyclone Gray Metallic 6 spd. AZPS 550hp package 480RWHP 7k mi. Mint Summer Driver (Sold)
1986 Buick Regal T-Type Turbo WH-1 1 of 463. all stock collector car FOR SALE
Old 04-12-2008, 12:33 PM
Default diamter yes
San antonio texas.. i can not gaurentee they will clear your claiper diameter wise YES they will clear a 14 inch rotor
they had 13 or 14 inch bear crosss drilled brakes all the way around on the HHR that these came off of..
they had the big pbr calipers however not the six pot so i cant say for sure if they clear 14 inch on your setup
