Old 04-16-2008, 07:16 AM
gearheads78's Avatar
gearheads78 gearheads78 is offline
Default C6 front with LS1 rear ....what master cylinder?
I will be running manual brakes. Anything out there that will bolt to the stock studs in my 66? I would prefer something OEM to keep with the look in my engine compartment.
66 Cutlass "Joe-Touring"
54' Olds 88 "Joe-Touring 2.0"
69 SS Camaro 4-speed (wife's)
Richard J.
If only I had the time talent and money to build everything in my head
Old 04-16-2008, 10:15 AM
ProTouring442's Avatar
I was planning on using the double master cylinder CNC Brakes makes for the Cobra crowd. It's made to be manual, though I was thinking of adapting it for my power setup. It uses a balance bar, so you should be able to dial it in.
You can find it on http://www.fortesparts.com/modules.cfm
Shiny Side Up!
Bill
Old 04-19-2008, 06:03 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
If you want something stock and cheap, try a 15/16" bore m/c. I belive a '67 Camaro came with a maual m/c with that bore size.
Old 04-19-2008, 06:45 AM
BBShark BBShark is offline
The C5 uses a 1" bore master and I believe the C6 does also. A C3 manual master cylinder is 1" also.
Old 04-19-2008, 07:31 AM
Tobin from Kore 3 suggested one from a 77 Malibu with manual brakes. I am going to give that a shot.
Richard J.
