Old 04-18-2008, 01:28 PM
tgvettes tgvettes is offline
Default Short Stroke LSX engine
Is there any short stroke factory crank for LS engines? I would like to build a modern version of a DZ302 based of a LS type engine. big bore short stroke.
As far as I have seen I think the difference between 4.8L, 5.3L, 5.7L and 6.0L
is basically same stroke different bore. So I assume aftermarkert crank is what I would have to do. Any input appreciated.
Tonny
Old 04-18-2008, 02:03 PM
Basing your business plan on taking cubic inches away from an engine would equal bankruptcy. I will be suprised if anybody has a destroker kit.
Old 04-18-2008, 02:19 PM
gearheads78's Avatar
gearheads78 gearheads78 is offline
6.0 block with a 4.8 crank. Shift at 9800.
66 Cutlass "Joe-Touring"
54' Olds 88 "Joe-Touring 2.0"
69 SS Camaro 4-speed (wife's)
Richard J.
If only I had the time talent and money to build everything in my head
Old 04-18-2008, 09:47 PM
Gearhead you a right on 9800 redline sounds good to me
except I thought the 4.8 had same stroke as 5.3 and 5.7
Does anyone have a stroke/bore list for all the different factory LS engines
Tonny
Old 04-18-2008, 10:17 PM
Tonny
4.8 = 3.27 vs 5.3 = 3.62 not sure if the bearing saddles are the same or not
http://www.mortec.com/borstrok.htm
Richard J.
Old 04-19-2008, 08:00 AM
clill's Avatar
clill clill is offline
for future reference it is DZ 302, not DC.
Old 04-19-2008, 08:10 AM
JamesJ JamesJ is offline
Since D and C are next to each other I am going to give him that one....
James J.
Old 04-19-2008, 08:33 AM
Thanks Clill
I should have known that.
Tonny
Old 04-19-2008, 11:08 AM
Rybar's Avatar
Rybar Rybar is offline
I think GM did this a few years back, they put it into a ~2000ish Pewter colored 4th gen with TTII's.
*Edit* Found it: http://www.superchevy.com/features/c...302/index.html
Here is a quote I found:
Westech that built the 302 out of the LS1. It used a 3.84 bore and 3.268 crank (4.8 Crank). It used the LS6/2001-2002 intake. TTS headers, Dyer Lite rods, ported LS6 heads(by Advanced Airflow) with pistons machined to match the combustion chambers, 1.9 ratio Jesel rockers and a 234/240 solid roller with .629 lift with a 110 lobe center. They did one thing a little different with the intake though , they ran the 2001 PCM program instead of modding the intake for the egr. I think it was a nice setup but the only way I would want to destroke an engine is if piston speed was over 4000 ft per second on a street car. Also I like short stroke power adder engines because I think that it is benefical to have a little overrev to work with. Just my .02.
Later,
Bart
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 04-19-2008, 08:41 PM
Thanks Rybar,
I thought I had heard something like that engine once before.
With that much cam in it shouldn't it make a lot more horsepower then 435 at 6000RPM
even if at maybe 7000-7500RPM?
Tonny
