Old 04-20-2008, 09:01 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Default Got it aligned, but...
Got the car aligned yesterday, everything went well, no suprises there... set the pinion angle while it was on the rack... no biggie... but, the car has been setting codes, so we hooked it up to a TechII to see what was going on. I'm getting a P0340 code, a cam position code. Upon further investigation, the sense wire has 5V on it all the time, even when disconnected from the CMP. Either something is goofy with the harness or the ECM has an issue. I have a schematic for the LS7/E38 ECM, but the CMP sense doesn't jive. Something strange is going on.
So.... 1 step forward, 1 step back.
And of course, here's the mandatory picture. The Lexus on the hoist in the background is getting a new motor. Apparently they can only go 45,000 miles without changing the oil.
My LS7 69 Camaro
Old 04-20-2008, 11:34 AM
awr68's Avatar
awr68 awr68 is offline
Default Thaks for the update Scott!!
Good to hear the car is road worthy other than the little electrical issue...I guess it's a good thing you understand that stuff like you do! I would be pretty lost!! You'll get it figured out soon and be putting miles on her!!
Tony
'68 Camaro
Old 04-20-2008, 12:31 PM
BC69's Avatar
BC69 BC69 is offline
So is she road worthy? Did you drive it over to the alignment shop?
Keep it up!
In memory of those gone before us
In gratitude for those who care.
Old 04-20-2008, 06:59 PM
Datsbad's Avatar
Datsbad Datsbad is offline
Scott, what computer is in this car?
I know when a computer is replaced or a new one used a CKP relearn has to be done. This will calibrate the crank sensor to the reluctor wheel.
""DEMON"
6.1HEMI/TKO 5 SPEED
CCW Black edition/BFG tires
Mini tub/AIR Ride
RMS Suspension
CURRENTLY FOR SALE !!!
Old 04-20-2008, 07:26 PM
XcYZ's Avatar
It's the GM E38, the stock computer for the LS7. We talked about doing the relearn if it was necessary. We hooked it up to a TechII and a scope, there's something wrong with the ECM as there's 5V present on C2-64, the input/sense for the CMP. I tested the harness and it's defintely not the problem.
From the symptoms, this problem has been there since the first time I started it. There's no signal from the CMP (because it's always high), and after cranking for 8 seconds, the ECM puts in a known number to limp it. It's always taken 8 to 10 seconds to start.
We'll see what Speartech has to say in the morning.
My LS7 69 Camaro
Old 04-20-2008, 08:22 PM
Vince@Meanstreets's Avatar
Sounds like its in the harness. Look for a pinch around the brackets or maybe just the wrong pin at the ECM.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 04-21-2008, 05:41 AM
XcYZ's Avatar
That was what I had first suspected, too, but there's no continuity between C2-64 to any other conductor in the harness.
My LS7 69 Camaro
Old 04-21-2008, 02:10 PM
jannes_z-28's Avatar
Might be the sensor.
Jan
Jan Suhr
Stockholm, Sweden
'69 Camaro Z/28 LS1/T56
Old 04-22-2008, 05:50 AM
XcYZ's Avatar
The sensor was disconnected and still had 5V present.
My LS7 69 Camaro
Old 04-22-2008, 06:08 AM
Stang's Bane Stang's Bane is offline
Wow Scott, I heard they developed wireless electricity, but I thought it would have took you at least a couple of years before you got it in your car
Car looks great. Did the alignment help the handling?? Hope so. I know you will get the gremlins figured out...
