When I purchased my Z28, it came with a 396 that someone dropped in at some point and had swapped out for the 302. I was unhappy with the performance and figured I would bite the bullet and do it right.
Call it Pro Touring Trans Am
After spending weeks researching and shopping around local engine builders, crate builders and whatnot, I ultimately decided on the zz502 simply because its a great base for me to build upon. I wanted streetable performance, and not to piss off the neighbors
too badly
 Keeping the M22...
Car in question:
Its currently in the shop getting the following done.
Engine Swap
Rebuild Gear Box
Window Roller Repair
Front Suspension rework
New Clutch
Replace Throwout Bearing
Rebuild Ujoints
Driveshaft Loop
New Horns
Slotted front Brakes/ New pads
Parts I've ordered so far:
Modo Innovations Pedal Covers
QA1 Coilovers with Adjusting tools
Aluminum Radiator with Dual Fans
Hotchkis Sway Bar
Replacement Window Crank Kit
Rosewood Steering Wheel Kit
Replacement Rear View Mirror
Moroso Solid Motor Mounts
Lokar Midnight Throttle Pedal
Lokar Throttle Cable Duo Pack
Driveshaft Safety Loop
