Old 06-02-2008, 04:30 PM
scherp69's Avatar
scherp69 scherp69 is offline
Default Power rack and pinion with hydraboost
Hopefully this is in the right category. Is anyone using a power rack and pinion set up and a Hydraboost system? I realize it will be alot of plumbing. I'm just wondering if you've run into any issues with it or anything you can tell me about it. Thanks.
Mike
Pro Touring 68 Acadian(Nova)
Prodigy Bar rear suspension
Wilwood 12.2" brakes
New Gen Splitters
LS3 and TKO600
Old 06-16-2008, 09:28 AM
fvike's Avatar
fvike fvike is offline
I'm running that combo in my Mustang. It works great, and I have very little crosstalk between the Hydraboost and Power rack. My PS pump is a KRC unit, so is my PS fluid resorvair. I also had the resovair fitted with another -AN 6 bung for the Hydraboost low pressure return line, instead of tunning a T.
You just need to run a PS pump that can handle the task, the KRC pump can easily change the flow-valve (big blue fitting on the pump) to get the gmp you need. Also the resorvair is big enough, so that you don't pump it dry.
The engine bay has been washed after this picture
Here's a picture when I installed it, the low-pressure return line isn't in that picture, because I hadn't fitted the extra AN bung, but you get the picture.
Hope this helped.
1969 Ford Mustang - Build progress - My FQuick site
Old 06-17-2008, 01:16 PM
scherp69's Avatar
Thanks for the photos. They will definately help.
Mike
New Gen Splitters
LS3 and TKO600
