Old 06-23-2008, 11:33 PM
ls1 nova ls1 nova is offline
Default What can I do?
What can I do to fit 275's on the front of a 1970 Nova(same as 1rst gen camaro) stock frame? Pics, backspacing, notch frame, anything will help! Can it work? Is it worth it? I just installed the Dse coilover conversion if that makes a difference. Thanks.
Old 07-06-2008, 12:18 AM
68Charger4myDAD 68Charger4myDAD is offline
Default Maybe..
Thats some meat for the front my first car was a 1974 Nova. You could use a fender roller check this out
http://www.eastwoodco.com/jump.jsp?i...emType=PRODUCT
I would go with a 245 or 265 depending what you want out of it. Hope this helps
Old 07-06-2008, 05:54 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Theres nothing to roll.
Pick up a set of used c5 Corvette rear wheels/tires, which are 9.5" wide, with a 275's. Remove studs from hub, and use bolts with a stack of washers to moch up the wheel to the correct backspacing you need. You only need two or three bolts for moch up.
I'm thinking you'll need around 6" of backspacing. The vette wheels have 7.6" of bs, so you'll need at least 1.5" of washers. With that much bs, I'm not sure if they'd hit the control arms or tie rods at that point.
At this point, you can see if you want to notch the frame or not.
I used this method when moching up my wheels for fitment. Nothing works better then an actual tire/wheel IMO.
Let us know what you find.
Old 07-06-2008, 09:16 AM
camcojb camcojb is offline
to add to the above, you'll likely have to limit the turning radius unless you modify the subframe. That size tire combo will definitely hit the frame before full lock so some sort of steering stop and getting used to 3+ point turns into parking spaces will be needed.
