Old 07-25-2008, 01:03 PM
rallye455 rallye455 is offline
Default What is the best way to remove undercoating?
I'm getting ready to work on the underside of my 72 442, What is the best way to remove undercoating?
Old 07-25-2008, 01:05 PM
rjsjea's Avatar
rjsjea rjsjea is offline
My car was completely torn down, had it sand blasted. Turned out very nice.....took all the rust, undercoating and grime away.
RobS
71 Demon, AlterK - 4 link GenIII hemi conversion
66 Rambler Classic Wagon, LS conversion -Scott's IFS/4bar-bagged
Old 07-25-2008, 01:07 PM
jy211's Avatar
jy211 jy211 is offline
just had the bottom of my 55' chevy done. Took away 99.3% of the grime and undercoating...
Old 07-25-2008, 01:56 PM
Denvervet's Avatar
Denvervet Denvervet is offline
I had to use a propane torch to heat it up a bit then it comes off like butter. Then I used paint thinner in a spray bottle ( after and separate from torching ) let it soak then wipe away with lots of disposable towels...the blue or paper ones. It is a lot of work but turns out well. My media blaster said the media won't remove undercoat.
68 camaro, 572, tko
Old 07-25-2008, 03:48 PM
gearheads78's Avatar
gearheads78 gearheads78 is offline
Heat gun and a wood paint stir stick to keep from gouging the metal for 98% of it. Wax/gease remover and a brush to aggitate the remaining residue.
66 Cutlass "Joe-Touring"
54' Olds 88 "Joe-Touring 2.0"
69 SS Camaro 4-speed (wife's)
Richard J.
If only I had the time talent and money to build everything in my head
Old 07-25-2008, 05:14 PM
I was looking for another method other than sandblasting. I just finished sandblasting the frame and will never do anything that big again, the mess is just too big.
Old 07-25-2008, 06:22 PM
BBC69Camaro's Avatar
Angle grinder with a wheel cup wire brush works pretty quick, just messy as all get up when you are underneath it.
Old 07-26-2008, 12:15 AM
monza's Avatar
monza monza is offline
Have some one else do it, is the best way!
Tiger torch, scraper, welding gloves and beer is next best IMO.
Dave
FUeL 69 Camaro RS
68 Corvair coupe
65 Impala SS
65 Corvair convert
64 Corvair Rampside
62 Corvair Greenbrier
http://www.sourceboards.com/
Old 07-26-2008, 11:55 AM
Thanks for the replies guys....looks like another messy project.
Old 07-27-2008, 01:47 PM
Jay Hilliard's Avatar
This is the way I did. It gets you dirty, but you can do it in your shop when you have time and saves $$ for other car stuff.
Jay
