Old 08-15-2005, 02:25 AM
*rayman*'s Avatar
*rayman* *rayman* is offline
Default Holley pro-jection on 454
The 68 camaro i just picked up has a 454 in it, putting out around 450hp.
I'm interested in using a holley pro-jection setup on it.
I can pick up a unit from one of the local importers for a mere $295aud. But there is no computer with it. Somebody has told me that the holley system uses all GM type plugs, and can be run from any ac delco/GM type computer. Is this true? Will the 900cfm unit be big enough to feed the 454?
68 BB SS Camaro - building it in Australia, where everything costs twice as much as it costs in the U.S.
Fuel prices suck!
Old 08-18-2005, 01:10 AM
*rayman*'s Avatar
so no one has any advice on the pro-jection setups????
I see MSD are making billet throttle bodies, am i better off going with one of their systems?
Fuel prices suck!
Old 08-18-2005, 01:17 AM
boostedbbc boostedbbc is offline
what rpm are you planning to take that 454 up to? 900cfm should work fine. I dont think the GM computer will work quite right to control the fuel injection. I think the newer TB for the pro-jection is a progressive system and has to have the correct computer to work properly but i am no expert so i would look for a 2nd opinion.
