Old 08-09-2008, 12:51 PM
Y-TRY Y-TRY is offline
Default Cleaning Cooked-on Oil
What's the best way to remove cooked-on oil from exhaust parts?
Is it as easy as just using oven cleaner?
What if the parts are ceramic-coated?
Ideas? Experience?
Old 08-10-2008, 11:47 AM
Blown353 Blown353 is offline
If the parts are shiny ceramic coated try Mother's aluminum polish. That's what the guys at Jet Hot recommend and it works well.
1969 Chevelle
Old 08-10-2008, 02:06 PM
the camtender the camtender is offline
Ideas? Experience?
DO NOT use oven cleaner!! It took the ceramic coating off my in spots.
BEST thing Iv'e found is SOS pads,then mothers alum.polish
Jerry
Old 08-16-2008, 01:53 PM
Roberts68 Roberts68 is offline
I've had good luck emulsifying the baked on oil or trans fluid from my headers by saturating it with penetrating oil. It seems to get gummy and then eventually soft enough to wipe/scrub off.
Old 08-22-2008, 02:07 AM
I did come across something that worked pretty well:
Liquid driveway degreaser. I soaked some shop rags in the stuff and started wiping. Even without an SOS pad the oil came off pretty well. Just in case the chemicals would effect the ceramic I made sure to rinse thoroughly with water. Worked like a charm on all of the pipes with no stains or spots.
