Old 08-13-2008, 07:28 PM
Musclecar's Avatar
Musclecar Musclecar is offline
Default 200-4r
Is anyone running a 200-4R in a 69 camaro? I am trying to find out how long my drive shaft needs to be. I was hoping someone is running this setup and can tell me the length that way I can go ahead and get my driveshaft done while I am installing the transmission.. I have a moser GM 12 bolt. Thanks
Garry
Carless at the moment
Old 08-13-2008, 08:06 PM
camcojb camcojb is offline
Garry
the 2004R is the same overall length and yoke as a th350/4-speed, but uses a th400 crossmember as the mount is further back. So I do not know the length, but a stock th350/powerglide/4-speed driveshaft would be the correct length.
Old 08-15-2008, 04:40 PM
Musclecar's Avatar
Thanks for the reply.. I found out today that it is the same length. I got the transmission in and put the driveshaft in place just to take a look at it and it fit! That will save me a few dollars! Thanks again for the replly...
Garry
