Old 09-30-2008, 06:35 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Default 12 bolt help, A-body.
I need a 12 bolt for a Chevelle I'm working on. I need it narrowed, and I also need the lca mounts and pring pads moved over 3" per side as I've narrowed the frame.
Moser said they'd only send the brackets loose, but I'd rather buy one with them intalled.
Any suggestions?
Old 09-30-2008, 06:59 AM
Mark, I do not know of anyone that will move them from stock as the jigs are only set for stock. We have done exactly what you looking at doing, and welded them on ourselves, no problem.
If it is a Moser, let me know, we can save you some money
Frank Serafine
Old 01-20-2009, 08:04 AM
MarkM66's Avatar
I could put the brackets on myself, but I figured it's one step I could save time on.
I figured Moser could do something slightly custom, but I guess not.
Old 01-21-2009, 07:10 PM
The WidowMaker's Avatar
currie might be worth a try, but like frank said, they all do it off of jigs. currie is narrowing my 12 bolt 2.5" per side and putting on 9" ends as we speak.
"The WidowMaker"
Old 01-25-2009, 12:12 PM
MarkM66's Avatar
Moser decided they could do it.
