Old 10-05-2008, 11:28 AM
evilzee28 evilzee28 is offline
Default Camaro aluminum front spoiler
Hi, does anyone know where I can get hold of an aluminum front spoiler for a 1st gen Camaro? I'm sure I've seen them on this site, but can't find the thread, thanks in advance...Nige
Old 10-05-2008, 11:57 AM
jannes_z-28's Avatar
Can't be to complicated to fab one up from aluminum sheet.
Jan
Jan Suhr
Stockholm, Sweden
'69 Camaro Z/28 LS1/T56
Old 10-05-2008, 12:08 PM
amaronut amaronut is offline
Any particular reason why you would want an aluminum spoiler? I know a top notch fab guy that could fab one up using a stock plastic one as reference...
Old 10-06-2008, 12:53 AM
I just feel that the plastic ones are a little flimsy & as the car's gonna be used for racing I wanted something a bit stronger.
Jan, I might well fab one up myself to a pattern of the original, no problems in doing it, it's just that I thought I'd seen one on the forum & if they were cheap enough it wouldn't be worth my effort to make one
Old 10-06-2008, 12:57 AM
Flash68's Avatar
Flash68 Flash68 is offline
I think Twist Machine and/or Jake's Rod Shop made some prototypes of both the front and the rear aluminum spoilers. I know they did the rear as I have pics of it.
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 10-07-2008, 06:37 AM
rsgt's Avatar
rsgt rsgt is offline
You can get the aluminum spoiler at spoilersbyrandy.com
Old 10-07-2008, 08:15 AM
clill's Avatar
clill clill is offline
I trying to count how many plastic front spoilers I have damaged over the years. Then imagining how I would feel when I did it to my trick aluminum one.
Old 10-07-2008, 08:51 AM
Lateral-g Moderator
I was thinking the same thing. At least when I damaged my spoiler that was all I damaged. A hard fixed spoiler would probably do some damage to surrounding body its attatched to. It needs to be something that blends in with the car color and theme and not be a center of attention piece, IMO.
Old 10-07-2008, 10:35 AM
Rick Dorion's Avatar
Rick Dorion Rick Dorion is offline
As another point of reference, when I used to race my 240Z at Lime Rock I put on an unbreakable chin spoiler after going through a few fiberglass ones. I ate a cone and mangled the lower valance. The spoiler was still perfect.
69 Camaro therapy program, 410, M22! SOLD
68 Camaro - SOLD
67 Bel Air - Hmmm.
Old 10-07-2008, 04:37 PM
deuce32's Avatar
deuce32 deuce32 is offline
hey guys , im recieving a spoiler that is custom . it will be made of steal then powdercoated . mine will have 4inch holes, one per side for air intake to carb, then two 3in holes one per side for my brake ducts . this will be installed on a 1st gen camaro . i have photos sent to me from manufacture (posted below ) but he is a small outfit whom will work with your application .
