Old 11-09-2008, 04:24 PM
olds olds is offline
Default Cutlass
Hello all, I have been trying to find a site to keep lists and details of everything I've done to my project. This one seemed to fit my project the best. I'm 21 years old and have had an 86 cutlass supreme since I began driving. I don't drive it anymore, but it has transformed into an ongoing project.
I would like to include pictures later to show everyone.
I haven't touched the exterior yet, all modifications have been on the interior and the engine I am building. Here's the vision of the car -
Engine - 383 with AFR 195cc heads, dual plane intake, forged everything bottom end, 750 cfm Holley carb, etc.
Drivetrain - ford 9" rear with 3.70 LSD, aluminum driveshaft, 700r4 or 200r4, the goal is to use the 400hp at the wheels most efficiently (ideas here would help a lot)
Interior - completely custom. Nothing will be stock but the windows and a few side panels I will need to post pics of this later.
Suspension - the reason I picked this forum. If any olds buffs are on here, the FE3X was a concept for creating a 1980's G pulling car. The final result was a moded 442 which could pull .97 g's around a skid pad. This is my goal to reproduce the concept.
Exterior - will match much of the FE3X concept car. All black, like the grand national.
Thanks for reading, hope everyone is cool here.
Old 11-09-2008, 04:36 PM
Engine work so far:
I began driving to Dallas from Houston for a gen 1 4 bolt engine which claimed to be rebuilt, cost - 800$. This was the first engine for me, and like a dummy I didn't take off the oil pan to check around. After getting the thing home, I checked it out and found the crank wouldn't turn, there was no valvetrain besides old assembled heads (which looked good). The most distressing thing was the engine was a 2-bolt, which I figured I could work with a block, but a 2 bolt wasn't what I wanted. I took everything out after looking at a few bearings which were new but scratched up. One of the main bolts was even missing.
It seemed someone threw some new bearings on and called it rebuilt. Oh well, lesson learned.
I took it to a machine shop and lucked out - these guys are the best, if you are in the north Houston area, will recommend them to you. I had them magnflux and mike the old block, which they said was salvageable but explained the cost of work that needed to be done.
They gave me a 2-bolt gen.1 block in better condition for FREE. Although I did pay around 400$ for the machine work.
Block work:
gen 1 chevy 350, 2 bolt main
boiled, magnafluxed, line honed
clearance for 383 crank, bored .30 over, honed with 300/350 grit
brass plugs, (ARP main studs and windage tray in future)
painted Olds gold - they didn't have the color so I painted it myself
They did such a good job on the block, I brought it back to them for the bottom end assembly. I am currently waiting on prices and will choose the best 4340 kit for the money. The reason for the kit is, in theory, there won't be any clearance issues as if I had bought the pieces separately.
More to come later on the interior...
Here is the look I am aiming for:
http://www.fe3xolds.com/DOWNLOADS/dvII.jpg
Old 11-10-2008, 08:25 PM
XcYZ's Avatar
XcYZ XcYZ is offline
Cool, welcome.
My LS7 69 Camaro
Old 11-11-2008, 05:57 AM
ProTouring442's Avatar
Welcome! I had an '86 442 for a while, until some lady ran a red light...
Post some pics of your project!
Shiny Side Up!
Bill
Old 12-08-2008, 04:10 PM
RomsMotors's Avatar
RomsMotors RomsMotors is offline
Good Choice in project car. Here the link to my cutlass project. I also attach a few pic of the car.
https://lateral-g.net/forums/showthread.php4?t=4070
Old 12-11-2008, 10:31 PM
89 RS's Avatar
89 RS 89 RS is offline
Sounds good, look forward to seeing more on your project.
Corey
1989 Camaro RS
Old 12-12-2008, 02:51 AM
98ssnova's Avatar
98ssnova 98ssnova is offline
dude just roll with it and lesson learned. Cool to see a project like this coming together keep up the good work and take the knock as lession learned and don't do it again. Good job bro
Old 01-25-2009, 01:37 AM
Thanks for the posts everyone,
The short block is assembled after a long delay
flat top hypereutectics, .030 over
no spider girdle, but will be running comp cams retrofit hyd. roller lifters for some extra power (also roller rockers)
cam is degreed, it's a comp cams XR282HR with intake and exhaust duration at 282/288, and valve lift at .510/.520
My budget only left room for a cast crank and I beam rods, which are pushing the limits on what this engine can do - they max out around 500 hp so I'm sucking it dry in terms of performance as it will put out right around 500hp/tq. I have a feeling this whole car will be built right on the threshold of street performance and high performance due to my college budget. I just don't want anything to crack or snap (a throttle stop will be one of the first additions to the top end list). The two bolt should hold up nicely with ARP studs rated at around 600 hp so the crank and rods are the weakest link of the set up. Hopefully they'll be stout through some decent revs up to 6 grand.
Old 01-25-2009, 02:24 AM
more engine pictures:
The heads story - I wanted to go with AFR's 195cc intake runner heads, the regular type, which flow about 270cfm at .500 lift. I looked around for the best deal but couldn't bring myself to spend 1500$ on a pair of heads. So the search continued until I found the new patriot freedom early SBC heads. They just started making them and they're the standard run-of-the-mill aluminum heads you might buy from any company. In short, they aren't AFR's, dart, or brodix. I called them up and they told me to call one of their distributors who had some promotional goodies for the first short while that the heads were being introduced. Talk about luck, I called them up and they had a pair of new patriot freedoms with a 195cc intake runner that were bowl blended (which I believe patriot also offers), pocket ported, dual springs set up for the roller lifters, and all at a price of 750$. Thats half price the AFR's for damn near the same performance take 5 or 10 hp. I also received a flow bench test which sets them at 255 cfm at a .500 lift. The other interesting thing is between a 500 and 600 lift airflow increases significantly, at a higher percentage than the AFR's (not saying the 600 lift is higher than the AFR's, but these heads close the gap considerably during this lift but fizz out afterward). So I bought a cam with a 510/520 lift to take advantage of this fact while saving vacuum for the street. The next luck with heads came a few days after I bought the patriots when I ran across some 283/327 heads someone had bolted onto an old 350 at a junkyard. If anyone wants the 327 heads we might work out a price - just send me a message and I can send you pictures.
Old 01-25-2009, 02:43 AM
Some body work:
The rusty roof needed some work so it was sanded, rust cured, primed, and painted. I used a two stage primer (not a real two stage, just filler and sealer) and sprayed some flat black and clear on the top. The idea was to get a satin finish but it will end up looking high gloss because of the clear. It's a shade under that deep black look from using high gloss black, it's almost a dark gray/black color. I use spray cans and only spray cans working one panel at a time because that's what I'm accustomed to. I've done some paint jobs with spray cans and people think I'm lying to their face they don't believe it. I have tons of hours left on the paint, most of which will be color sanding and buffing, but this is just the start. You'll be able to use it as a mirror just like any paint job when it's finished, but it isn't a show car or trailer queen.
Here's where some ideas could be helpful - I am thinking about this dark gray/black glossy color for the entire top, then the line which follows under the windows across the side of the car make a 1 - 2 inch deep/high gloss black stripe, then a simple flat black on the entire bottom of the car (that way rocks and chips won't worry me because there won't be any finish on the bottom half). How does that sound? Any other ideas would be awesome, the theme is black.
Here's the car as it was a few days ago and in the infant stage of its build. Let me know if the bare fiberglass bones for the front clip looks good or dumb, I need some input before I go head first into that project (it's just a base, the final product - if that decision is made, will be clean and follow body lines).
