Old 11-17-2008, 09:36 PM
asudevil asudevil is offline
Question Wheel Fitment Question
Hello All! Sorry for the dumb question but I want to make sure I am right before I waste alot of money. I found some 17" torq thrust wheels that were on a 68 camaro. I want to buy them to put on my 1970 Chevelle Malibu. Will they fit or is there a possibility they will be a different lug pattern? Thanks for your time.
Old 11-17-2008, 09:45 PM
awr68's Avatar
awr68 awr68 is offline
Lug pattern should be the same....unless the rears were for a Ford 9" rear end. I would look into the backspacing/offset though....
Tony
'68 Camaro
Old 11-17-2008, 09:46 PM
As a rule they will fit unless they did not fit the camaro. Do you know the sizes and backspaces?
Frank Serafine
Old 11-19-2008, 11:51 AM
Exclamation Thanks for the Advice!
Thanks for the help guys! As for the backspacing I do not know yet, but I will be finding out soon. Is the backspacing between a camaro and a chevelle very different? Thanks everyone!
Old 11-19-2008, 11:52 AM
Default Sizes
Oh yeah......By the way the sizes are 17x8 & 17x9. Thanks again!
Old 11-19-2008, 01:59 PM
JayR JayR is offline
Lateral-G Supporting Vendor
They'll fit no problem because the Chevelle has way more wheelwell. Your only foreseeable issue will be that there's too much room to spare like a spacesaver spare on a truck but you can add some tire height and width to help fill the wheelwells out.
