Old 11-20-2008, 08:53 AM
bigtyme1's Avatar
bigtyme1 bigtyme1 is offline
Default Electric life Power Windows
Is anybody having issues with electric life windows going up extremly slow. My buddy has installed 2 motors and they both go up slow. we thought there might be a binding problem but even on a bench test the motors are slow. Electric life will not return because they said everything is tested before it's shipped. I'm getting ready to order a set but I wanted to see if the problem can be solved first. What other options are there for electric windows out there. Gotta give my list to Santa.
69 RS Ragtop
[email protected]
Will trade wife for parts!!!
Old 11-20-2008, 09:11 AM
fesler's Avatar
fesler fesler is offline
We use them on everything and they are actualy fast, what car is your buddy putting them on. They are not as fast as a new GM truck but for a power window in a Camaro or truck they work great. It is possible you have two bad motors or they have been sitting to long.
Chris Fesler
Fesler Built - Scottsdale, AZ
Old 11-20-2008, 10:44 AM
BonzoHansen's Avatar
BonzoHansen BonzoHansen is offline
Do they use off the shelf GM motors?
Scott from NJ
Old 11-20-2008, 03:00 PM
bigtyme1's Avatar
He has used them in a 69 Camaro, and I know generaly Electric life is a great product' I guess it's possible that he has two bad motors. I'm going to see him over the week end to see how he made out.
69 RS Ragtop
[email protected]
Old 11-20-2008, 03:07 PM
MtotheIKEo MtotheIKEo is offline
Is he getting 12-14 volts at the regulator?
Old 11-20-2008, 03:28 PM
HRBS's Avatar
HRBS HRBS is offline
We used EL's kit for the The Mustang Vert and they go up pretty slow. But Lightning fast down. I had to make extra 1/2" thick rubber pads to mount on the bar stops so the glass doesnt shatter.
HRBS on Facebook
Old 11-20-2008, 03:45 PM
4mm 4mm is offline
IRRC, Frank from Prodigy has mentioned on PT.com that EL was in the process of upgrading motors due to some being slow in certain applications.
Old 11-20-2008, 04:11 PM
XcYZ's Avatar
XcYZ XcYZ is offline
It's not that they're slow, it's that they have no torque. They need more gear reduction or something. Sure, they go down damn fast, but go up slow and have a hard time getting the last 1/4 inch to get a good seal.
Super easy to install, though.
My LS7 69 Camaro
Old 11-20-2008, 04:57 PM
dhutton dhutton is offline
Nu-Relics sells kits that use US made Delco motors.
Don
Old 11-20-2008, 07:49 PM
bigtyme1's Avatar
Well it's good to know that they are working on the problem
69 RS Ragtop
[email protected]
