Old 11-28-2008, 08:03 PM
rladd1968 rladd1968 is offline
Default T56 Questions
I recently purchased a T56 out of a 1995 Z28. I am trying to cross-reference the numbers on it, but, I can't seem to come up with anything! The numbers are 1386-000-009 and all of the charts I find skip from 1386-000-007 to 1386-000-011. I need the gear ratios and torque ratings. Also, this transmission will be bolted to a Gen V 454.........any flywheel advice??? Thanks!!
Old 12-01-2008, 09:07 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
'94-'97 all had the same gear ratios and torque ratings.
Is your engine a one piece rear main?
Old 12-01-2008, 10:36 AM
Thank you. My motor has a one piece seal.
Old 12-01-2008, 06:23 PM
MarkM66's Avatar
I'm thinking a stock t56 flywheel will bolt right to it.
Is it internally balanced?
