Old 11-30-2008, 05:11 PM
thedude327 thedude327 is offline
Default Are there any tips to drilling axle shafts for larger wheel studs?
I was wondering if it would be better to drill out the axles for larger wheel studs or go with aftermarket axles? I am looking to upgrade the wheel studs from 7/16" to 1/2" and am looking for some opinions.
Thanks in advance
Paul
1973 Z28 Street-touring project.........
Old 12-01-2008, 08:24 PM
chicane's Avatar
chicane chicane is offline
Sure... make sure you get the 'interfearence fit' correct for the knurl size you are upgrading to.
Although... depending on the rear differential you are using... a set of aftermarket KA axles (Tom's Differentials) or the like... are hard to beat for the price and re-newed reliability/durability are worth the expense for most. I guess it would really come down to what the bearing surfaces look like on your current axles.
Old 12-01-2008, 09:27 PM
Tom.A's Avatar
Tom.A Tom.A is offline
I would find a rear end builder to do them for you. With the right tools it can be done quick. I think I paid $50.00 for Currie to press out/install new studs and that included drilling out the holes. I first tried a couple of local machine shops and only one would try it....I quickly realized he was gonna jack the axles up and said maybe I better wait. IMO spend the extra money and have a pro do it.
Tom
Old 12-01-2008, 09:50 PM
Mick Mc's Avatar
Mick Mc Mick Mc is offline
Very interested.
I need my 5/8 studs installed into my 12 bolt axles, so any concrete information would be helpful.
subscribed
Mick
Old 12-02-2008, 03:43 PM
Thanks for the info. , I called a local gear shop and they said that they'd do it for $50-75 . Looks like provided the axle shaft bearing surfaces are ok , then this is an inexpensive way to upgrade the wheel stud size. I believe that this price was for the drilling only, not the cost of the studs, but I'll have to check that.
Paul
Old 12-02-2008, 04:05 PM
gearheads78's Avatar
gearheads78 gearheads78 is offline
Find a machine shop to do it. I learned the how hard the axles are to drill when I wore out 2 bits before I had finished my 3rd hole. $75.00 at the machine shop well spent.
66 Cutlass "Joe-Touring"
54' Olds 88 "Joe-Touring 2.0"
69 SS Camaro 4-speed (wife's)
Richard J.
If only I had the time talent and money to build everything in my head
Old 12-02-2008, 06:18 PM
MarkM66's Avatar
MarkM66 MarkM66 is offline
I've seen post where people just tap out the 7/16" holes for 1/2" threads, and use button head bolts as their wheel studs.
Old 12-02-2008, 06:37 PM
68protouring454's Avatar
its very easy to drill out, its all in the proper drill size, and also having enough meat to drill, not too little so it wipes the bit out quick.
jake
Jake's Rod Shop
Old 12-04-2008, 07:39 AM
daytonayellaz daytonayellaz is offline
I did mine at home, pressed them out with a bench mounted vice and a socket, had a helper to hold the axle. Drilled the holes and pressed them in with my impact gun and a few old lug nuts with large fender washers under them.
Old 12-05-2008, 01:14 PM
If your drilling out for larger wheel studs and using the press in studs, what amount of interference fit do you need between the knurl of the stud and the new hole? Is there a spec. for this?
Thanks again for any replies
Paul
