Old 12-01-2008, 11:24 AM
Steve Chryssos's Avatar
Default Billet Gauge Bezels for Auto Meter !!NEW!!
Another one-of-a-kind product from Twist Machine! ...And they fit EVERY make, model and type of hot rod rod as long as it runs Auto Meter gauges. While it might seem like a very simple part, a really trick machining process (patent pending) was developed to create these ultra-thin gauge bezels for a custom, but integrated look. The end result is something that you might only see on a one-off build from Rad Rides or Alan Johnson. But if you don't have any blank checks lying around, our gauge bezels will treat you to the same vibe every time you get behind the wheel of your car.
The rear face is a perfect match for Auto Meter's standard bezel. Our billet bezels attach by way of supplied silicone "DOTS". There's no need to take apart your dash or hack up your gauges. The dots work really awesome, but if you're doubtful, you can apply a thin bead of clear silicone for a permanent installation. Supplied instructions will detail either method of attachment.
Here are the details:
-Fits almost all Auto Meter® Gauge sizes and series (not Auto Gage or Street Rod. Does not fit 5" recall tachs--yet)
-Ultra thin! Only .090" clearance required between gauges
-True billet: 6061-T6 aluminum
-Available for 5", 3-3/8", 2-5/8" and 2-1/16 gauges"
-Easy Install - Super Adhesive “DOTS”
-Choose Polished/Brushed or Black Anodized finish
-Sold Individually or as “Dash Paks” that are perfect for Covan Classics and other gauge clusters.
Secure online ordering HERE or give us a call. Bezels are in stock, but orders will be shipped in the sequence that they are received.
Thank you for looking.
/Steevo
________________
Steve Chryssos
Ridetech.com
Old 12-01-2008, 11:41 AM
paulk68 paulk68 is offline
any pics of the black anodized?
Old 12-01-2008, 12:04 PM
Awesome parts. The perfect Christmas present. I just ordered a black anodize Dash pack + 2 additional for Michael's Monte Carlo. Automatic check out worked perfect.
I will do some before and after pics when we install them
Frank Serafine
Old 12-01-2008, 08:40 PM
XcYZ's Avatar
XcYZ XcYZ is offline
Checked them out at SEMA. Pretty slick.
My LS7 69 Camaro
Old 12-02-2008, 12:34 AM
mazspeed's Avatar
mazspeed mazspeed is offline
Would this fit a 67 cluster?
Old 12-02-2008, 01:41 AM
Flash68's Avatar
Flash68 Flash68 is offline
Very slick. Yes, also anxious to see pics of black.
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 12-02-2008, 03:02 AM
Cread01 Cread01 is offline
x2
Old 12-02-2008, 05:07 AM
The black stuff is a week out. Only because we decided to polish AND anodize. Get the surface perfectly smooth and the black will be blacker-er. I'l post pix as soon as possible. We will hold prices on black bezels even though they have double surface finishing (polishing and anodizing).
Sorry, I should have made that clear in my original post.
________________
Steve Chryssos
Ridetech.com
Old 12-02-2008, 10:00 AM
Woops! Sorry I missed this one....
Yes. But 5" gauges in stock clusters are an interference fit. The gauge bezels add .090" diameter (45 thou material thickness), so the gauges must protrude slightly more than they would without the bezels. Or, install them from behind.
________________
Steve Chryssos
Ridetech.com
Old 12-23-2008, 07:24 AM
Black bezels are done. The picture does not do them justice. And here are polished bezels in a 69 Covan dash.
________________
Steve Chryssos
Ridetech.com
