Old 12-01-2008, 12:45 PM
stylEmon's Avatar
stylEmon stylEmon is offline
Default Auxillary Injection ONLY ::: NO INTERCOOLER
I thought ya'll might like to see the results of my latest data log.
Specs are Garret T04E .60 compressor, 1.24 turbine
Tubular manifold, tail 38mm wastegate, 9 lbs spring.
Devil's Own 150 psi pump
50/50 distilled water/methanol
M2 nozzle pre-compressor
M7 nozzle post compressor
I especially like how the AIT keeps going down as the boost and RPM go up.
Old 12-01-2008, 02:38 PM
camcojb camcojb is online now
yep, I use water injection on every forced induction build I do, cheap insurance.
Old 12-01-2008, 02:49 PM
stylEmon's Avatar
I am using only AI for intercooling. I may eventually run an intercooler as well, that way it will truly be insurance.
Do you use devil's own or aquamist?
Old 12-01-2008, 03:14 PM
by insurance I meant it really helps prevent detonation, allows more timing and boost on pump gas also. I've used most every brand out there, currently running Snow Performance.
Old 12-01-2008, 05:48 PM
stylEmon's Avatar
i see what you mean by insurance. Most people I've run into use AI in addition to physical intercoolers.
I would run pure methanol for the cooling. But I run at least 25% water for detonation deterrent. Since it's cold, I've gone up to 50/50.
Old 12-01-2008, 06:00 PM
water is a much better heat absorber than methanol. The methanol does give a slight octane boost, and adds additional fueling since it burns (which may or may not be an advantage), but for pure heat absorption go straight water.
I had a procharged 540 without an intercooler and straight water injection, made over 800 rwhp with our crappy 91 octane. The stuff definitely works with or without an intercooler.
Old 12-01-2008, 06:21 PM
stylEmon's Avatar
I've heard MANY people say water has better cooling properties, but in all the logs I've seen from my own car, the more methanol, the colder in the intake charge. Maybe alcohol has less cooling than water, but methanol...?
Old 12-01-2008, 08:45 PM
Water is a much better heat absorber than alcohol/methanol. I think the big benefit happens in the combustion chamber, not air temp drops. But if it works for you..................
a quick Google found this:
Is water injection a proven technology for improving engine performance?
Similar to the benefits of using hydrous ethanol blends, many water injection systems for high performance engines use a mixture of water and alcohol (approximately 50/50). The water provides the primary cooling effect for air and fuel injection mixtures due to its great density and high heat absorption properties. Water instantly reduces air intake charge temperatures by 50-200 plus °F. This provides a substantially cooler and denser air charge for greater expansion of power within the combustion chamber. It is becoming quite common to find engine builders using 91-93 octane gasoline combined with water/alcohol injection to support engines well over 1000+ horsepower. One top engine builder in the industry has already made upwards of 1700+ horsepower with a ProCharger supercharger carbureted big block Chevrolet on 93 octane regular unleaded gas using 100% water injection.
Old 12-02-2008, 09:13 AM
stylEmon's Avatar
Are they talking about the car you built?
Old 12-02-2008, 10:44 AM
6D9 6D9 is offline
I plan on running water injection on my new Procharger set up without a intercooler. I hope it will allow 6-8 psi on 91 with my sorta high 9.8 to 1 comp.
69 Camaro
491 BBC
TH400/GV OD
Currie 9"
Rushforth Livewires
