Old 12-05-2008, 03:03 PM
John510's Avatar
John510 John510 is offline
Default 68 Camaro Subframe Alignment help
So I tried test fitting my LS1/T56 into my 68 camro and the tranny was off to one side in the trans tunnel. Looks like it could scoot over about 2 inches. Could this be because my subframe was not aligned when I put it back on the body?
Anyone know how I can line this thing up without having to tow it over to a frame shop?
Thanks!
[SIGPIC][/SIGPIC]
Old 12-05-2008, 05:14 PM
youthpastor's Avatar
John, I think you should stop now and let me buy the car...o crap I already have one
anyways enough with the peanut gallery-
center subframe bolts (2) - out of the six- have alignment holes that line up with the cowl- look close you'll see 'em have fun- Chris
Old 12-05-2008, 08:40 PM
eville's Avatar
eville eville is offline
Thanks!
did you change your engine frame mounts? Your car was a BB right? IIRC Bigblocks sat to the right 2" to clear the steering box.
Steve
'68 Camaro - 355", TKO600, SpeedTech Arms, ATS-AFX Spindles, Hotchkis Springs, Forgeline Wheels, C5 Brakes (Kore3), Holley Terminator EFI
Check it out Here
Old 12-05-2008, 08:49 PM
68protouring454's Avatar
the tunnel is 3/4 off center in the camaro as well
Jake's Rod Shop
Old 12-06-2008, 12:47 AM
John510's Avatar
Steve,
I sold the BBC stands and replaced them with SBC stands.
Jake,
Not quite sure what you mean. Is the tunnel on the floor not center in the car or should my tranny be off by 3/4 ?
[SIGPIC][/SIGPIC]
Old 12-06-2008, 05:46 AM
the tunnel in the camaro is 3/4 of an inch off center, if you measure you will find the tunnel is offset if i remember right to the passenger side.
so yes if you measure pinch weld to pinch weld, the tail shaft will be 3/4 off of dead center, but thats fine as the tunnel is offset anyway
Jake's Rod Shop
