Old 12-23-2008, 07:57 AM
69MyWay's Avatar
69MyWay 69MyWay is offline
Default Stock 69 Camaro axle width??????
Does anybody know the stock width for a 69 Camaro axle????
I'm having to get my modified axle cut down to STOCK width...but am not sure what that is.
Also - is that measurement to the axle face to rotor - or is it including the rotor?????
THANKS!
Old 12-23-2008, 04:43 PM
67rsssls's Avatar
67rsssls 67rsssls is offline
I am almost positive it is 60" hub to hub.
Steve
Old 12-23-2008, 05:29 PM
7TSS's Avatar
7TSS 7TSS is offline
Mine measures 60.25" axle face to axle face
Goodwin
Old 12-23-2008, 05:48 PM
BBC69Camaro's Avatar
I believe mine was 59.50 flange to flange, 10bolt open carrier.
[edit] Same as my new 12 bolt Moser at stock width.
Old 12-23-2008, 05:56 PM
bobhamilton15090 bobhamilton15090 is offline
i agree with 60" flange to flange
Old 12-24-2008, 02:05 AM
69MyWay's Avatar
Cool....the cobb webs are falling off now and I am remembering what/why we did what we did when we set up the long 9" ...
Yes, I believe mine was 60" (drum brake) - and I had built 2 3/4" wooden test spacers to mount the rear C5 rims to the car.
Since the LS1 rotors are about 1/4" thick at the hub, we cut the 9" at 55" hub to hub - making it 55.5 overall with the discs on....
Okay...this makes me feel better now. I don't have a stock axle to compare and I dropped the 9" at the speedshop yesterday to put it to a stock width - which will be 60" in this case when he takes 2.5" off each side.
Make sense?
THANKS!
