Old 01-04-2009, 09:29 PM
James OLC's Avatar
Default OneLapCamaro - Marquez Design Interior
I've neglected to post any pictures of the '67's interior - the foundation of which is Marquez Design's updated dash and door panels - so I thought I would snap some pictures before I started pulling it apart to finish up the fire system and wiring.
The new Marquez Design dash is awesome! As you can see it is a complete replacement and goes all the way to the windshield. Instruments are courtesy of the Racepak IQ3 logging dash with autometer fuel pressure and level gauges.
The quick release hub makes life a bunch easier getting in and out and is especially handy when you have to work under the dash. The column is a trick custom Ididit shorty that is a direct bolt in replacement for the stock dash.
The center console is out of a '71 Camaro that we uphostered to match the dash. The double din head unit isn't in place yet but a Kenwood piece with GPS navigation is coming soon. Shifter is a Pro-5.0 from American Touring Specialties and the bezel is something that we fabbed up in the shop. The window switches will be out soon and and ISIS In-Touch unit will be fit and will house all of the cars switches.
AC controls and vents are from Vintage Air. The billet handle on the drivers kick panel is the remote hood release.
Seats are from Cobra; the back seat seat area is pretty basic but houses the Fire Safe fire system as well as the RaceLogic traction control ECU.
Sorry that the pictures aren't the greatest but one of the issues with working on projects like this in the garage at home is that space and lighting can be limited at best.
In my opinion the Marquez Design interior really brings the car together and is one of the best investments that I made in the build. Not only is the styling awesome, it adds a bunch of much needed room and makes creates a fantastic driving enclosure! Hats off the Pascual and everyone at Marquez Design for another awesome product!
I'm working now on addressing some of the issues and potential issues that we identified at the Optima Invitational in the hopes that we can be at 100% for the begining of May.
Cheers!
Old 01-04-2009, 09:46 PM
Flash68's Avatar
Flash68 Flash68 is offline
Simply stunning!
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 01-05-2009, 03:34 AM
68protouring454's Avatar
james, looks awesome.
Is the column or the adapter to run a quick release a special part or something produced? is it a fine spline on the quick release hub or course so the wheel feels sloppy when not driving?
jake
Jake's Rod Shop
Old 01-05-2009, 08:44 AM
Jr's Avatar
Jr Jr is offline
This is one of the best 67's out...
Old 01-05-2009, 05:29 PM
James OLC's Avatar
jake
Jake,
The column is an Ididit GM replacement column with an adapter for a MOMO wheel. The FIA approved quick disconnect bolts in place of the wheel and essentially sandwiches between the column and wheel (it is available for other patterns IIRC). It doesn't use fine splines, instead it used larger pins that are machined essentially in two planes. Three pins parallel the plane of the column shaft and keep the wheel from rotating while the two disconnectable pins are perpandicular to the column.
So far I have not been able to feel any difference from a 'hard mounted' wheel so I am satisified at this point.
James
1967 Camaro RS - The OLC
1967 Camaro RS - Recycler
1969 Camaro - Dusty
Old 01-05-2009, 06:10 PM
thanks james, do you have a link for the adapter?
Jake's Rod Shop
Old 01-05-2009, 06:45 PM
looks great as does the rest or the car James.
Old 01-05-2009, 07:23 PM
XcYZ's Avatar
XcYZ XcYZ is offline
x2.
My LS7 69 Camaro
Old 01-05-2009, 07:30 PM
thedugan's Avatar
thedugan thedugan is offline
Where are the front support bars for the roll cage hidden. Unreal I cant see them but they must be behind the pillar
Doug L.
68 Camaro RS/SS Conv. LSA/T56
67 Camaro RS LS2/T56 "NutKse"
Old 01-05-2009, 07:34 PM
XcYZ's Avatar
James, I forgot to say how awesome the interior looks. And if you feel like posting a bunch more pics, it sure wouldn't hurt my feelings.
That's some good carnography.
My LS7 69 Camaro
