Old 01-08-2009, 02:06 PM
JamesJ JamesJ is offline
Default Using aftermarket Hydraulic Thowout bearing
I remember reading that someone made an adapter or maybe a new hose to be used when using the factory hydraulic clutch master with an aftermarket hydraulic throwout bearing such as a McLeod unit. I think that it replaced the quick connect with and AN fitting. Does anyone remember this? Or know where to get something that will work?
James J.
Old 01-14-2009, 04:54 PM
1 Dwn Cam's Avatar
1 Dwn Cam 1 Dwn Cam is offline
What is your setup? LS motor and LS T-56?
This will give you an Idea.
http://www.cardomain.com/ride/2368130/1
Vrbancic Brothers Procharged 406
781.5 HP @ 6500
701 @ 5500
14 psi.
Old 01-15-2009, 01:31 PM
Tiger's Avatar
Tiger Tiger is offline
I was planning to use a T5 bellhousing with the attached slave so I cut the quick connect and silver welded an AN to it.
never got around to use it but its a way of doing it.
André
2009 Chrysler 300C Touring.
3.0 liter V6 diesel, five speed auto.
1968 Chevelle Coupe.
355cid, Viper T56, Corvette C4 IRS (Dana 44) and C4 IFS. Porsche 6 and 4 piston Brembo's.
1980 Chevy Van (shortie G10).
355cid, TH350, 8.5" 10bolt posi and Belltech spindles.
*NOW PARTING OUT* 2000 BMW 540i Wagon*
Bikes
1968 Benelli City Bike
1990 Yamaha RD 350
1990 Yamaha TZR 125R
1991 Yamaha TZR 125R - RD350 engine, Aprilia RSV forks, RS250 wheels and shock
2010 Buell XB12SS
Old 01-16-2009, 01:47 PM
LT-T56 with a SBC
Thats what I will do if I cant find this... I think it may have been a new hose that has has the AN fitting already installed.
James J.
