Old 01-14-2009, 03:16 PM
tellyv's Avatar
tellyv tellyv is offline
Default T56 on a big block
I have a t56 out of an lt1 camaro and want to put it on a big block, its a 2 piece rear main and its internally balanced, so can I use the stock lt1 flywheel? Does anyone make a light weight one? Any help would be great. Thanks Telly
Old 01-14-2009, 03:25 PM
MarkM66's Avatar
MarkM66 MarkM66 is offline
No to LT1 flywheel, they only work on oprms.
Ram makes a aluminum flywheel.
https://lateral-g.net/forums/show...light=flywheel
Old 01-14-2009, 04:55 PM
79ZED 79ZED is offline
There are a number of places that make flywheels in both aluminum and steel that will work. i used a Fidanza aluminum behind my int. balanced BBC.
John
Old 01-14-2009, 08:17 PM
tellyv's Avatar
thanks guys!!!
Old 01-15-2009, 05:12 AM
MarkM66's Avatar
Here's the Fidanza flywheel.
http://store.summitracing.com/partde...1&autoview=sku
Old 02-04-2009, 06:28 PM
KEISLER's Avatar
KEISLER KEISLER is offline
We stock this neutral balanced part and can make you a killer price on it and free shipping. PM if interested or call and ask for Gene.
Old 02-04-2009, 08:05 PM
Cread01 Cread01 is offline
A little off topic but I have been wanting to put this transmission in my car with a big block also... the engine is externally balanced though. Will I have to have everything rebalanced with a new flywheel? It's an auto right now.
Old 03-25-2009, 06:37 PM
MarkM66's Avatar
No. Just get a flywheel with a weight. Mc Leod makes one.
