Old 01-15-2009, 07:55 AM
tobyflh tobyflh is offline
Default square tubing
I'm going to start building a new frame for my truck and I wanted to know what grade steel tubing to use. The main rails are going to be 2x6x3/16 or 7 ga.
Old 01-15-2009, 08:19 AM
abadsvt's Avatar
abadsvt abadsvt is offline
1/8" thick is the standard for the industry. 3/16" is way to thick for an entire frame unless it has a specific purpose because that frame is going to be super heavy. A frame built out of 1/8" and has good bracing with be plenty strong. I am no expert though. What are you building exactly? What is the purpose of the truck? anyways good luck
Josh
Old 01-15-2009, 08:32 AM
I can run 1/8 but I want to build some curves in it which would be 4 sided and then weld the corners. But I want it to match the tuding.I want to match the existing frame but pinch the rear rails. I don't have a bander for square tubing. I hope you understand what I'm saying. Awsome truck you are building. Toby
Old 01-15-2009, 09:33 AM
Rusty G Rusty G is offline
How about checking some aftermarket suppliers that sell rear rails, back half kits and such?
They should have the material thickness listed.
I am sure after checking a few you will find a pattern.
