Old 01-30-2009, 03:30 PM
jcal87's Avatar
jcal87 jcal87 is offline
Default please tell me how to fix this.
this is between my door and fender on both sides
Old 01-30-2009, 03:40 PM
rjsjea's Avatar
rjsjea rjsjea is offline
Take it to a body shop, probably will rebuild or replace the door hinges and re-align.
RobS
71 Demon, AlterK - 4 link GenIII hemi conversion
66 Rambler Classic Wagon, LS conversion -Scott's IFS/4bar-bagged
Old 01-30-2009, 04:26 PM
elitecustombody's Avatar
yep, have the hinges rebuilt and re-align the fender with door,then fix the paint chipping
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1998 GS400TT widebody
1969 Firebird
1979 Firebird LS3,DSE,Baer
1938 Dodge LC pickup
Old 01-30-2009, 05:46 PM
youthpastor's Avatar
looks like the crown is too far in on the pic on the right - removing a shim from the lower bolt on the fender will push the fender out
Old 01-31-2009, 02:56 PM
jcal87's Avatar
I don't quite understand what you mean by rebuild the door hinges? Isn't there a set area to put them in and they open and close fine?
Old 01-31-2009, 04:27 PM
comp-spec's Avatar
It looks like your door is sitting low? How is it to the rocker?
Grap the end of the door were you open it and lift up and down to see if there's any play. If its loose you need to rebuild your hinge if there tight you just have to do some realigning
Pete
Competition-Specialties.com
Old 01-31-2009, 04:50 PM
jcal87's Avatar
both hinges are tight one does make a loud popping noise when shut but other than that they are fine. i think the fender and door are just to close because when you open and close it there is maybe a millimeter of a gap
Old 01-31-2009, 05:07 PM
open the door about 1/5 of the way and lift on the bottom rear corner, see if there is any play,if so, I'd put new bushings and pins on the hinges,then proceed with aligning the fender with the door and fixing the paint chipping, but if your hinges are fine, align the fender with the door
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1969 Firebird
