Old 02-14-2009, 11:48 AM
jcal87's Avatar
jcal87 jcal87 is offline
Default I have a squeal in my car help!
Alright guys need your help again after i changed my clutch out and put everything back together my car is making a squealing noise.and no its not the belt.it sounds as if it is coming from the bell housing and its not a constant sound it will quit then get louder than quit when it is idling but does make the noise when driving as well idle any ideas to what this could be?
Old 02-14-2009, 11:53 AM
Rybar's Avatar
Rybar Rybar is offline
I had a similar issue with my T56. It ended up being the Pilot Bearing in the tranny which had to be replaced.
Killer Customs diagnosed the problem and did the work for me. Thanks Blake
This of course is after I changed almost every accesory including the water pump.
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 02-14-2009, 11:56 AM
jcal87's Avatar
well its a brand new pilot bearing i hammered it in myself and the tranny its a muncie 4 speed if that helps any
Old 02-14-2009, 11:59 AM
May very well be your throwout bearing as well. If you have a stethescope listen on the engine case and tranny case. I would bet it will be louder on the case the squeal is closest to. Bottom line is it's coming back apart more than likely. Did you pull it apart for the pilot bearing?
Old 02-14-2009, 12:11 PM
jcal87's Avatar
even if the throw out bearing is brand new as well
Old 02-14-2009, 12:42 PM
Rybar's Avatar
My clutch an throw out bearing were new. But the squeel didn't appear for quite a while.
1969 CAMARO RS
Old 02-14-2009, 01:03 PM
jcal87's Avatar
yeah this one started right away
Old 02-14-2009, 02:44 PM
So you replaced the throwout and pilot along with the clutch I bet. Sounds like a bad part of improper installation.
Old 02-14-2009, 02:56 PM
jcal87's Avatar
everything went in smoothly only thing i could think of is the pilot bearing because i had to hammer it in with a rubber mallet could it just be something just breaking in i mean there's not much to a clutch installation.
