Old 03-10-2009, 07:44 PM
aany001's Avatar
aany001 aany001 is offline
Default what booster and master should I use??
hello folks.....I installed C5 front brakes and LS1 rear brakes on my 69 camaro and wondering what booster should I run as well as which master cylinder would work?
thanks in advance
Steve
Old 03-14-2009, 06:11 PM
aany001's Avatar
anybody?
Old 03-14-2009, 06:29 PM
almcbri's Avatar
almcbri almcbri is offline
I had the same question awhile back. I was told to run a stock 12" delco disc/disc set-up from a second gen. with my C5 brakes.
I still haven't decided. I like the looks of the DSE one but was also told the pedal was really touchy. Not really sure but it sure looks better than the stock delco.
Old 03-14-2009, 07:39 PM
Apogee Apogee is offline
A single 11" diaphragm booster has about the same area and hence boost as a dual 8" unit. Both are decent options with a 15/16" to 1" bore master cylinder with the C5/C6 front and LS1 rear calipers. The DSE dual 9" unit should give you approximately 30% more boost and is supplied with a 1" bore MC.
How much vacuum does your engine generate at idle?
Tobin
KORE3
www.kore3.com
Old 03-15-2009, 08:21 PM
aany001's Avatar
I dont know yet on the vacuum amount cause I havent built the engine yet.But its basically a stock 350 vortec with a ZZ4 hot cam and 1.6 roller rockers.
