Old 03-11-2009, 05:38 AM
aany001's Avatar
aany001 aany001 is offline
Default mini tub upper shock location help
I am about to weld in my upper shock mounts in my 69 camaro that I have mini tubbed.Where should they be and what angle should the shocks be? Also does the shock mount with the large barrel up or down?
Thanks in advance.
Steve
Old 03-12-2009, 05:22 PM
awr68's Avatar
awr68 awr68 is offline
Steve, did you install a DSE upper x-member? It's OK to install the shocks at an angle...but don't go more than 20*.
Tony
'68 Camaro
Old 03-12-2009, 09:21 PM
aany001's Avatar
Anthony I did install the DSE upper shock brace so I just called them and they told me not to go more that 5degrees of an angle.
Old 03-12-2009, 10:38 PM
awr68's Avatar
There you have it!
Tony
'68 Camaro
Old 03-13-2009, 06:32 AM
XcYZ's Avatar
XcYZ XcYZ is offline
I wouldn't angle them at all.
My LS7 69 Camaro
Old 03-13-2009, 09:54 AM
ZMAN1969's Avatar
ZMAN1969 ZMAN1969 is offline
Default upper shock mount
BRP hotrods sells a weld on OR a bolt in upper x-member for this - im using the weld in on my 69 check brphotrods.com
'69 Trans Am clone under construction -still!
LS6 6speed
69 R/S Z28 Daytona Yellow 302
90 Formula / Firehawk clone
1999 Firehawk
1969 Chevelle SS 396
Old 03-13-2009, 10:46 AM
slenning's Avatar
slenning slenning is offline
I installed my shocks straight up - no angle.
Steve
70 Camaro - in process https://lateral-g.net/forums/showthread.php4?t=50636
69 Camaro LS7/T56 https://lateral-g.net/members/lenning/
69 Camaro SS396/350hp
64 Chevelle - patiently waiting
2014 Z28 Ashen Gray
2010 Camaro 2SS/RS Black w/White stripes (wife's car)
2015 SS (the 4 door one) Wife's other car
Old 03-14-2009, 12:36 PM
awr68's Avatar
He is running leafs....doesn't that require a slight shock angle?
Tony
'68 Camaro
