Old 03-24-2009, 03:57 AM
usa-69z usa-69z is offline
Default Best coil over frontend?
Im doing my research on coilover front suspension. Can i buy a kit which has everything i need , ie; shox,springs top & bottom A arms. ? Who has best product for the money which all bolts together and works well.
(i want the front end low-69 camaro) Does my swaybar still bolt up? anything else i need ? thanx in advance for ya help
Gav
Old 03-24-2009, 04:30 AM
dhutton dhutton is offline
I think the Chicane LM kit from ATS is one of the best coilover conversion kits you can get.
Old 03-24-2009, 05:14 AM
Thanx for input, do they have a site i can check there products out?
Old 03-24-2009, 05:31 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Here's the link:
www.AmericanTouringSpecialties.com
My LS7 69 Camaro
Old 03-24-2009, 11:47 AM
JamesJ JamesJ is offline
But can you get it? All there stuff is up in the air and if you can order something, delivery will be way down the road. (as far as I know)
DSE makes a coilover kit
James J.
Old 03-24-2009, 04:39 PM
The website shows the AFX spindles on backorder but everything else in stock, including the Chicane LM kit. Send Tyler an email and ask him.
Trouble with the DSE coilover conversion is you have to drop the control arm to adjust the coilover. The engine also needs to be out to install the coilover mounts. I think the Chicane is a better setup, assuming it is available.
Don
Old 03-24-2009, 05:08 PM
awr68's Avatar
awr68 awr68 is offline
If you are set on ATS then I would buy these and source the control arms and coilovers of your choice directly. You will need to get on the waiting list for the Tall AFX spindles....or do the G-Mod yourself and use stock height spindles. Tyler is really hard to get ahold of right now.
Or, call DSE and do the one stop shopping deal. The nice thing about their c/o conversion is that it corrects the geometry with new upper control arm mounts...this allows you to use a stock height spindle weather it be a GM spindle or an ATS AFX (stock height).
Another great option is Speed Tech they have great parts and pricing.
Do your homework, you have options!
Tony
'68 Camaro
Old 03-25-2009, 02:15 AM
redfire69's Avatar
redfire69 redfire69 is offline
Do any of these options give you more than an inch and half drop adjustment (over stock)?
Ron
69 Camaro Redfire
Old 03-25-2009, 03:10 AM
I just had a good read thru the 'speed tech' site. Thats what im after for sure. One thing what is the difference between kit 1 and kit 2 besides $500.?
They look the same and have no reference to any differences.
(69 camaro coilover kit)
cheers, Gav
Old 03-25-2009, 07:26 AM
Mkelcy's Avatar
Mkelcy Mkelcy is offline
cheers, Gav
Tubular lower control arms.
