Old 04-02-2009, 08:41 PM
ROKN69's Avatar
ROKN69 ROKN69 is offline
Default A humble introduction
Hello everyone,
My name is Roger, and I have a '69 Camaro that I've been building / working on for more than 8 years now. It took about 4 years to get running and now I've caught the Pro-Touring bug and want to upgrade the suspention, tires and wheels to make the car competitive.
Here's a picture of the car when I first purchased it and when it was going off to the body man. I picked it up for $1400. This was in December 2002.
As you can see, a very humble beginning.
These next few shots are when it was at the body shop:
Along with a new core support, and right front fender:
Both rear quarter panels were replaced:
Rear deck view (interestingly there was no need to replace the metal between the trunk and rear window):
Primered - Left rear view:
Primered - Frontal view:
Just painted - Frontal view:
Almost done at interior shop, November 2003:
In this next shot the car is 95% complete (body wise). It is sitting in my driveway and is more or less driveable. I find out soon that I have major engine issues.
This is the finished interior (except the door poppers weren't hooked up yet, but they are now):
Interior view (again circa 2005):
I am by no means finished with this car. I'm am working on engine #4 now, as the first one was an old tired engine I put in the car and it didn't last long. After saving up for a while (2007 time frame) I purchased another engine from what I thought was a reputable company out of Pheonix, AZ. They shipped me a piece of junk, which I ran for two years (but not much, due to the problems). I tried to warranty the engine and they went out of business, thereby stranding me. That was about $5500 (installed) down the drain. So I saved up again, and put a 383 in it which cost me about $6000 and it was supposed to have about 475 HP. It only put out 420 HP, and that was because the heads I used were from the previous engine and weren't what I was told they were. So I am now building another 383 (using the same rotating assembly from engine #3 (specs to follow) and I purchased new heads, cam and pistons.
I have been through the school of hard knocks on this build. It's my first build, and if ONLY I knew then what I know now. I try not to dwell on the bad because I'll just cry.
I recently (within the past 6 months) made good friends with a car and engine builder who has graciously taken me under his wing. He is helping me build another 383 (engine #4). Here's the specs:
AFR 210 "race" heads, with 2.08 / 1.6 valves.
Competition Cams advertised 300/306 (actual 248/254) with 562/580 lift. The cam grind is 12-444-8 with 106 degree lobe separation.
Keith Black flat top .030 over pistons
Scat 400 crank (4340 forged) with H-Beam (4340 forged) rods.
New block with 4 bolt splayed caps, bored .030 over
Hurricane Plus intake (polished)
Demon 750 CFM Carb (street/strip)
2" primary custom headers in to 3.5" collectors
3" exhaust with 2 chamber flow masters
During this time I am working to clean up the wires and what not under the hood. I'm hoping to have the engine installed and running in two to three weeks.
The suspention is stock, and I'm wanting to upgrade the car (after the engine is installed) to make it Pro-Touring worthy.
I appreciate the site and I look forward to getting to know all of you, and hopefully from here on out the build goes smoother than it has in the past.
Cheers,
--Roger
My project, pride & joy:
2006 Mustang GT (Daily Driver)
1969 Camaro SS
Youtube Walk-around
New Motor - Idle & Drive
First N2O Pass Oct 2010
Old 04-03-2009, 06:31 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Welcome, Roger. Great introduction.
My LS7 69 Camaro
Old 04-03-2009, 09:22 PM
awr68's Avatar
awr68 awr68 is offline
Welcome Roger! You sure saved that car!!
Tony
'68 Camaro
Old 04-03-2009, 09:23 PM
almcbri's Avatar
almcbri almcbri is offline
welcome aboard, nice car
Old 04-03-2009, 09:54 PM
NOT A TA's Avatar
NOT A TA NOT A TA is offline
Welcome! Great intro
John Paige
70 Firebird Esprit, 400 TA clone type "The 14 car"
lab-14.com
Old 04-05-2009, 03:54 PM
Welcome. That's a nice color you chose.
Old 04-09-2009, 03:40 PM
ROKN69's Avatar
Thanks, guys.
As an update, I'm putting together the short block on Friday, and hopefully will have the long block assembled and ready to put in the car on Saturday.
So maybe in a week or two I'll have it running again.
The next step is a 4 link rear suspension with mini-tubs (probably the ones DSE sells), along with tubular A-Arms and rack-and-pinion for the front. Followed immediately by new rims and tires, of course.
1969 Camaro SS
Youtube Walk-around
Old 04-09-2009, 07:39 PM
Ralphlovs72chev's Avatar
Ralphlovs72chev Ralphlovs72chev is offline
Keep us posted....
Old 04-09-2009, 08:07 PM
Talk about rags to riches, looks great!
Welcome
Frank Serafine
Old 04-10-2009, 05:17 AM
ProTouring442's Avatar
Looks great! Don't worry about the 8 year time frame, I've been building my 442 for 13 years and it's never run!!!
Shiny Side Up!
Bill
