Old 05-06-2009, 05:37 PM
SteveMcqueenRules's Avatar
SteveMcqueenRules SteveMcqueenRules is offline
Default EZ Wire VS. American Autowire
My car is a 1964 Oldsmobile Cutlass I need a new chassis wiring harness.
I have seen a EZ 21 Circuit Universla wire kit advertised for $185
and I go to the American Autowire website and the harness is like $569 for their 1964-67 Chevy Chevelle Classic update Harness
and the Painless 18 Circuit Universal Muscle Car kit is about $706.
I assume the EZ Wire and Painless kits are more of Universal kits since they don't have specific kits.
Does anyone who has experience with wiring know what the differences are?
You're gonna be hangin' on for mercy when I get this sucker rollin'- FALFA
Old 05-08-2009, 07:12 AM
XcYZ's Avatar
XcYZ XcYZ is offline
I'm not all that up on the other kits, but I used the American Autowire Classic Update kit in my car and was extremely impressed with it in regards to how complete it was, the documentation, schematics, systematic design approach to the install, etc. I'd buy that kit again without a doubt.
My LS7 69 Camaro
Old 05-08-2009, 10:31 AM
Rhino Rhino is offline
One of the main components to the higher AAW kit price is the fact that it also comes with all connectors and light buckets. That can't be said for a lot of aftermarket manufacturers.
Old 05-08-2009, 10:37 AM
Musclerodz's Avatar
EZ Wire and AAW are not even the same class of kit. There is so much more that comes with the AAW kit, it is not even funny. Painless is as much or more than AAW and not even vehicle specific.
Mike Redpath
Musclerodz & Customz
facebook page
Old 05-09-2009, 10:00 AM
asifnyc's Avatar
asifnyc asifnyc is offline
Default ez kit
I'm in the process of re-wiring my '73 AMC Javelin with the EZ wire kit. I looked at the prices of the painless and AAW kits and cheaped out
my car is completely non-stock; aftermarket gauges, no hvac, power door locks/trunk popper, moved the dimmer switch to the turn signal stalk, etc, etc...
as Rhino stated above, the AAW direct fit kits will come with all the factory style connectors so you can just mount it and start plugging things in. the EZ kit requires you cut and terminate the ends as needed. again, that was fine for my situation but might not be what you want.
the EZ wire kit comes with the following, pre-terminated, connectors: gm style ignition switch, floor dimmer switch and the steering column connector (for the steering column you have to actually plug the wires into the correct connector for your car but they just pop right in). that's it. every other wire will need to be terminated by you.
for my purposes the ez wire kit does the job. the only thing I'm not happy about is that it's not a "bulkhead" connection setup. What I realize now is that I would have preferred to pay for a fuse block/engine harness that connects through the firewall and "sandwiches" together (like a stock setup). the ez wire kit engine harness is just fed through a hole you drill in the firewall). I believe some painless kits have a fuseblock/engine harness connector that sandwiches together like a stock unit and I assume the AAW kit's as just like stock...
there are some pics/posts on my install of the ez kit (still not done) on my blog (see my sig). good luck.
oh, one other comment about AAW that has nothing to do with their product quality... I HATE their website... makes my eyeballs melt. drives me crazy when people try to get "creative" with websites. just make a site that's easy to read and navigate... just my .02 cents.
-asifnyc- penngrove, ca (SF bay area) asifnyc.com - Javelin Blog
1974 AMC Javelin NASA American Iron road race car
1974 AMC Matador road race project
1975 AMC Gremlin shell
1973 AMC Javelin/AMX - street
1975 AMC Gremlin - street
1970 AMC Javelin shell
1962 Rambler American vert
Old 05-09-2009, 11:10 PM
gearheadgarage's Avatar
gearheadgarage gearheadgarage is offline
The AAW harness is worth the extra $$$. Unless you're unemployed, your time is worth money. You save many hours running with AAW or Painless- and AAW is only more expensive because their kits are more comprehensive.
Furthermore, installs are way cleaner to boot. Good luck!
Old 05-10-2009, 07:08 PM
I think I should go with the AAW kit. I agree their website sucks. It looks like it was designed by someone who doesn't know design.
Old 05-10-2009, 09:23 PM
COYBILT's Avatar
COYBILT COYBILT is offline
Agreed, don't buy some piece of junk harness its not worth it
1965 GTO convertible
2009 GM Design Award winner
Triple black with Subtle yet massive Modifications.
Old 05-11-2009, 08:23 PM
Theresa Theresa is offline
Old 05-12-2009, 08:10 AM
BonzoHansen's Avatar
BonzoHansen BonzoHansen is offline
Originally Posted by Theresa View Post
Scott from NJ
