Old 10-09-2005, 10:07 AM
Hydratech®'s Avatar
Hydratech® Hydratech® is offline
Supporting Manufacturer
HydratechBraking.com
Talking Attention All Hydratech Customers And Hydraulic Brake Assist Users
We are currently in the process of designing a superior new model of hydraulic brake assist unit! While this will take some time to design and ultimately achieve production, the time frames may not be nearly as distant as some may initially believe. What we would like to do here is to receive as much feedback as possible for use in designing the newest superior model hydraulic brake assist units. To that end, would you please take a moment to provide some highly appreciated feedback and survey information, as after all, we are going to be producing these systems for you!
Some of the key design improvements currently in discussion are:
* High strength Aluminum alloy instead of cast iron for much lighter overall weight, which may also be optionally polished to a very high appearance grade finish
* Shorter overall assembled lengths
* Larger register sizes to accommodate 2 stage / quick take up design master cylinders
* Slotted master cylinder mounting holes to accommodate various different styles of master cylinders
* Adjustable master cylinder pushrod
* Higher hydraulic flow through capacities / rates
* User adjustable power output – picture literally being able to optionally turn up or down the desired levels of available brake assist!
* Multiple keyway mounting
* Interchangeable brake pedal rod design
* Stand alone operations not requiring the use of power steering if desired
* Remote accumulator design for packaging in tight areas
* Individual valve body assemblies for use in tailoring the pedal response and feel characteristics, along with various available port configurations to accommodate a large range of possible plumbing options
* Highly enhanced low friction seal technology for precision fluid control
Your comments and suggestions are welcomed! Please advise
There IS a difference - Thank you for choosing Hydratech!
Paul M. Clark <-- the Ukrainian - Slava Ukraini !
Founder / Master Engineer
Hydratech Braking Systems ®
www.hydratechbraking.com
Old 10-09-2005, 11:26 AM
KAA's Avatar
KAA KAA is offline
This would be number 1 on my list:
This would be a nice addition:
Keith
'70 El Camino SS L78 396 - It's back!
Lateral-g Feature
Chevy High Performance Feature
'09 Viper SRT-10X
Car Craft 2009 RSE Winner
Car Craft Feature
NARRA Road America TTU Record Holder
Old 10-09-2005, 03:24 PM
XcYZ's Avatar
XcYZ XcYZ is offline
The 2 things Keith pointed out, as well as the shorter overall length would be great for getting it into tight places.
My LS7 69 Camaro
Old 10-09-2005, 03:37 PM
67Sally's Avatar
67Sally 67Sally is offline
Yes a shorter overall length would be nice.
W.
William Rouleau
Project PonySnake
Old 10-11-2005, 03:17 PM
Hydratech®'s Avatar
Default General replies
Hi Guys - thank you very much for the feedback so far!
Yes, aluminum IS definitely at the absolute top of the list, as this is a point that has had the largest amount of discussion. The shorter overall length will be challenging, though I'm confident that it can be done. The variable power adjustment option is also high up there on the list, as even I myself would enjoy this option VERY much!
Let's keep the input and suggestions coming
Old 10-12-2005, 01:36 PM
syborg tt's Avatar
well put me down for one
marty-mj
Old 10-12-2005, 09:29 PM
mhr mhr is offline
I have a customer car that would like to have one like your talking about that we are doing now. How far out are we talking?
Old 10-20-2005, 10:15 AM
Hydratech®'s Avatar
Default Timeframes
How far out are we talking? THIS seems to be the toughest question to answer, as there are many variables that may all come together to cumulatively put the debut off as far as a year from now. What is the largest potential delay? Testing and certifying all of the components carefully for durability and safety before circulating the systems to the aftermarket.
The current thinking is 6-8 months on the inside, a year on the outside.
