Originally Posted by XcYZ
The engine died and the assist didn't work? Something is wrong there... the nitrogen reserve cylinder accumulates and stores pressure so if you lose power steering you would still have some assist.
Several years ago when I had my car at the strip with the 434, it died as I went through the lights. I had 3 full stabs at the brakes with power assist with the engine off (going about 120mph), after that I just had a hard pedal.
Thats the theory behind the system...
from the autocross thread:
https://lateral-g.net/forums/show...19&postcount=1
My problem is, my car doesn't have power steering so I'd have to add power steering pump, all bracketry, just for the hydroboost. And at that point, I might as well add Power Steering and a 12:1 ratio box. It adds up pretty quick. $2000 just to lock up my brakes, lose some power, and add more things that can fail at the track.
Or just find a booster that works for $300 and call it a day.
Would I be able to run a manual master with my OEM style calipers?
Fronts:
Rears:
I just want a nice predictable solid pedal, I don't care if it requires some strength because I'm a big guy, but I need full lock up and I need to rely on my brakes on track days.
For now I baby the car because the brakes are the weak link...
