Old 06-03-2009, 05:50 AM
bigtyme1's Avatar
bigtyme1 bigtyme1 is offline
Default Vacuum Lines LSI Help
OK we got the car running last week but I have no idea what to do with all the vacuum lines on the manifold and valve covers.
I have a 98 LS1 with perimeter valve covers.There are two outlets on the passenger side and one one the drivers side rear.
There are 3 on the throttle body and 1 on the rear of the manifold.
Any Ideas? Picks would be very helpful.
69 RS Ragtop
[email protected]
Will trade wife for parts!!!
Old 06-04-2009, 02:19 PM
anthony 69 anthony 69 is offline
i can fax you pic if you have a fax #
Old 06-04-2009, 02:46 PM
bigtyme1's Avatar
pm sent
69 RS Ragtop
[email protected]
Old 06-04-2009, 03:13 PM
fax sent hope it helps diagram from 02 camaro...............good luck..............anthony
Old 06-04-2009, 03:18 PM
bigtyme1's Avatar
Thanks Anthony, more of a factory set up but it may get me started. I have no emisions on this motor
69 RS Ragtop
[email protected]
Old 06-04-2009, 03:21 PM
bigtyme1's Avatar
I will take a pick with out the covers
69 RS Ragtop
[email protected]
Old 06-04-2009, 03:29 PM
#1 hvac is for factory a/c control you can plug #2 power brake booster #3 evap system you can plug #4 evap you can plug #5 evap purge disconect and plug #6 throttle body #7 go' to pcv valve #8 egr valve disconect unless your runing cat's #9 & 10 go to breather or cold air intake hose i don't think you need both.
Old 06-04-2009, 03:33 PM
nice looking engine bay look's like your doing a bang up job.
Old 06-04-2009, 03:44 PM
bigtyme1's Avatar
Thanks, it's coming along slowly.
69 RS Ragtop
[email protected]
