Old 10-18-2005, 10:51 PM
Y-TRY Y-TRY is offline
Default Nagging 1st Gen Camaro Questions..
I know this could belong on a dedicated Camaro site, but this seems to be pretty close..
There are two issues with my car that have ewxisted since day one and I can't figure them out. Maybe your experience can help me:
1) My clutch-fork goes into the bottom of the firewall. I've always had small blocks in the car with manual transmissions. Using either a stock or aftermarket bellhousing and/or fork, the fork pushes into the firewall behind it when depressed. It actually has pushed-in a hole about 5" wide and protrudes into the cabin-side by about 1.5 inches. This is with every fork/bellhousing combo I've had. For the pedal to have full range the firewall simply doesn't afford enough distance to allow for the fork. The frame-side engine mounts appear to be the right ones, and the engine seems to be sitting in the right place. Did automatic cars have a differently contoured firewall? Maybe I have a car that was later converted? If it weren't for the hole made by the fork, there's be no place for it to go. Depressing the clutch has just created a gaping hole. Have any of you seen this before?
2) The car sits crooked. I have talked with a few other Camaro guys who have the same problem. I thought that all the new suspension would alleviate any sagging or whatever, but the car still sits noticably higher to one side, when viewed from the rear. There is at least 1" difference between the tire/fender gaps between the sides. All of the body panels are straight and the gaps are even. I'm guessing that the rear subframe was tweaked prior to installing all the panels. It's almost like the suspension favors the passenger side so that they are even with a driver (only) in the car. Hmm.
I think these may be common issues seen by guys who restore these old cars, but I don't know. Any ideas? Any common stories?
Old 10-19-2005, 05:41 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Which fork pivot do you have? It sounds like you have the short one. Have you tried an adjustable fork pivot?
My LS7 69 Camaro
Old 10-19-2005, 07:09 AM
Derek69SS's Avatar
My dad's '68 also suffers from the leaning problem, even after new springs. He thinks the subframe is tweaked though, as he bought it totalled in 1975 out of a local salvage-yard with heavy front-end damage.
Old 10-19-2005, 03:01 PM
I have the adjustable pivot, and it's meticulously set to the right distance. It's just weird. But the same problem occurred with factory fork and bellhousing in the car.
It was suggested to me once that I may have big block frame mounts, but I don't think so. The rest of the linkage is aligned great and everything. Simply nuts.
Old 10-20-2005, 05:38 AM
Rick Dorion's Avatar
Rick Dorion Rick Dorion is offline
The correct small block fork is GM # 3892632. I had that problem and replacing the fork (which sure did look the same) cured the issue. Also with the correct block to pivot ball distance which you said you have. Do you have a scattershield or anything non-stock.
69 Camaro therapy program, 410, M22! SOLD
68 Camaro - SOLD
67 Bel Air - Hmmm.
Old 10-20-2005, 06:18 AM
TA219's Avatar
TA219 TA219 is offline
I cant tell you how my 1st gen will sit (if it will be higher on one side) but i can tell you that my 4th gen did the same thing. I never knew what caused it but it does not seem to be a rare occurrence
67 Camaro
10 Camaro
Old 12-03-2005, 10:49 PM
ArisESQ ArisESQ is offline
yea my 67' actually has that same leaning problem, and it been bothering the hell out of me... if anyone knows what causes this PLEASE post a reply... the car sits a good 1.5 inches lower on the driver side.
