Old 08-26-2009, 11:12 PM
PASD U PASD U is offline
Default Reverse Mini Tub??
While doing some research about the possibility of fitting a 10" wide wheel on the rear of my 65 Chevelle I ran across a term and source that I have not been able to define or confirm. The actual phrase was "DSE Reverse Mini Tub". I've looked my butt off and have neither found the phrase to be used anywhere else nor a Mini Tub kit on DSE's website for a 64/65 Chevelle. If anyone has any information to the validity of this can you post it up. Thanks.
Old 08-27-2009, 12:49 PM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Where did you hear it?
Old 08-27-2009, 01:57 PM
While doing research of some 64/65 Chevelles. Ran across the same red 64 I don't know how many times. Can't keep up with who owns it now and how many people have had some kind of hand in it. Anyway, that's not the most important thing.
Every time the mods are listed it's listed literally as "DSE Reverse Mini Tub".
Ok enough talk. Link:
https://lateral-g.net/forums/showthread.php4?t=19802
Old 08-27-2009, 06:47 PM
MarkM66's Avatar
Hmm.. not sure what that's suppose to mean.
Bottom line, if you need more room, you'll have to widen the tubs and narrow the frame.
Old 08-29-2009, 01:03 PM
HotRod68Camaro's Avatar
HotRod68Camaro HotRod68Camaro is offline
Check out the outer wheel tubs on this camaro. I want to say that they made the outside portion more vertical. Maybe thats what it means.
http://www.detroitspeed.com/projectp...ueger_main.htm
Kyle
