Old 08-28-2009, 09:40 PM
aany001's Avatar
aany001 aany001 is offline
Default what master to use
I was wondering if a 2002 C5 master and booster bolt up to my 69 camaro.I am running C5 front brakes and LS1 rears and wondered what I should run for a master and booster.
thanks in advance
Steve
Old 08-29-2009, 09:28 AM
Apogee Apogee is offline
The C5 dual-9" booster will not bolt up to the first-gen F-body firewall without modifications to the firewall and/or the booster bracket and push rod, but it can be done. There have been a few threads here and on pro-touring.com with similar installations, both with C5/C6 boosters and 98-02 F-body boosters.
We suggest running a 15/16" to 1" bore MC with vacuum boosted applications, depending on the level of vacuum, size of the booster and pad selection to a certain extent. Single 11" and dual-8" have approximately the same effective area, but about 25% less than the dual-9" for reference.
Tobin
KORE3
www.kore3.com
Old 08-29-2009, 02:15 PM
aany001's Avatar
I just got home from picking up a 02 C5 master cylinder and booster assembly.I bolted up the master to my factory booster and it looks and fits exactly the same.I am running 02 C5/C4 front brakes and LS1 rear disc setup.Can I run my factory booster with the C5 master?? Does anybody have any idea how my pedal will feel?? Do I still need to run a porportioning valve?? Is it worth the trouble to modify my firewall to install the corvette booster??
Thanks in advance.
Steve
Old 08-30-2009, 04:36 PM
almcbri's Avatar
almcbri almcbri is offline
Originally Posted by aany001 View Post
Can I run my factory booster with the C5 master?? Does anybody have any idea how my pedal will feel????
I would like to know if this would work as well. I have thought about doing this.
Old 08-31-2009, 05:24 PM
Yes, you can run the C5 master cylinder with your factory booster as long as it's not one of the long push-rod versions used on some early cars. The stud spacing is the same at 3.40" and the pilot register diameters are as well at 37.5 mm [1.476"].
Assuming you're running the single-11" diaphragm booster, your pedal feel will be ~25% stiffer than a Corvette if the pedal ratios are the same, which I doubt...but that should at least get you close for comparison purposes.
We recommend running an adjustable proportioning valve in the rear circuit so that you can tweak your brake bias to match your car's setup and maximize your braking performance, not to mention allow you to compensate for changes you may make to the car in the future.
Tobin
KORE3
www.kore3.com
Old 08-31-2009, 07:47 PM
aany001's Avatar
how can I tell if its a long push rod style? Is it the rod inside the car or between the master and booster that you are talking about? And thanks for the info thats awesome
Steve
Old 09-02-2009, 11:16 AM
Steve
Technically, they're both push-rods, but I was referring to the one between the booster and the MC piston. The boosters with short push-rods are about flush with the master cylinder mounting surface, give or take. The long push-rod units extend outward by a little over an inch and would require a corresponding deep hole in the master cylinder piston, so there's a clear difference between the two.
Tobin
KORE3
www.kore3.com
